BRepOffsetAPI_MakePipeShellPy.setAuxiliarySpine problems
looo
Postby looo » Thu Mar 09, 2017 11:42 am
The API for MakePipeShell.setAuxiliarySpine has slightly changed. I used this to create helical gears in this functions
This is the error I get for all 3 possibilities of typeOfCOntact
  File "/home/lo/.FreeCAD/Mod/FCGear/gearfunc/_Classes.py", line 152, in execute
    wi, fp.height.Value, fp.height.Value * tan(fp.gear.beta) * 2 / fp.gear.d)
  File "/home/lo/.FreeCAD/Mod/FCGear/gearfunc/_Classes.py", line 451, in helicalextrusion
    pipeshell.build()
<class 'Base.FreeCADError'>: Unknown C++ exception
Is there any example/documentation on how to use this for newer occ-versions?
Chris_G
Re: BRepOffsetAPI_MakePipeShellPy.setAuxiliarySpine problems
Postby Chris_G » Fri Mar 10, 2017 8:36 am
I have been experimenting with PipeShell last week.
I was able to use the auxiliary spine with :
ps.setAuxiliarySpine( auxSpine, True, long(2))
I was evaluating the possibility to use this tool to make a Sweep on 2 rails.
But I get crashes when I have more than 1 profile.
example code :
from FreeCAD import Base
import Part
import FreeCADGui
DEBUG = 1
def debug(string):
    if DEBUG:
        FreeCAD.Console.PrintMessage(string)
        FreeCAD.Console.PrintMessage("\n")
doc = App.ActiveDocument
def parseSel(selectionObject):
    res = []
    for obj in selectionObject:
        if obj.HasSubObjects:
            i = 0
            for subobj in obj.SubObjects:
                if issubclass(type(subobj),Part.Edge):
                    res.append((obj.Object,[obj.SubElementNames[i]]))
                    #res.append(obj.SubElementNames[i])
                i += 1
        else:
            res.append((obj.Object,['']))
    return res
selection = FreeCADGui.Selection.getSelection()
RailObj1 = Part.Wire(selection[0].Shape.Edges)
RailObj2 = Part.Wire(selection[1].Shape.Edges)
profiles = selection[2:]
Profiles = []
for prof in profiles:
    Profiles.append(Part.Wire(prof.Shape.Edges))
ps = Part.BRepOffsetAPI.MakePipeShell(RailObj1)
ps.setAuxiliarySpine( RailObj2, True, long(2))
for pro in Profiles:
    debug("Adding profile")
    ps.add( pro, False, False) # Shape, contact, rotate ortho
if ps.isReady():
    ps.build()
    Part.show(ps.shape())
doc.recompute()
With the attached test-file:
- select 2 opposite edges (rails) and 1 profile (crash with 2 profiles)
- run the code
PipeShell.fcstd
(7.75 KiB) Downloaded 3 times
OS: Ubuntu Zesty Zapus (development branch)
Version: 0.17.10460 (Git)
Build type: None
Hash: 91c59c7910436c44ede608e29d9a90a287121a11
Python version: 2.7.13
OCC version: 7.1.0
crash log :
#0  /lib/x86_64-linux-gnu/libc.so.6(+0x35860) [0x7fe284d75860]
#1  0x7fe24b251a30 in BRep_Tool::Surface(TopoDS_Face const&) from /usr/lib/x86_64-linux-gnu/libTKBRep.so.7+0x20
#2  0x7fe24bc537aa in BRepFill_PipeShell::Add(TopoDS_Shape const&, TopoDS_Vertex const&, bool, bool) from /usr/lib/x86_64-linux-gnu/libTKBool.so.7+0x1fa
#3  0x7fe24bc54272 in BRepFill_PipeShell::Add(TopoDS_Shape const&, bool, bool) from /usr/lib/x86_64-linux-gnu/libTKBool.so.7+0x62
#4  0x7fe24e706e61 in Part::BRepOffsetAPI_MakePipeShellPy::add(_object*) from /usr/lib/freecad-daily/lib/Part.so+0xc1
#5  0x7fe24e706ed3 in Part::BRepOffsetAPI_MakePipeShellPy::staticCallback_add(_object*, _object*) from /usr/lib/freecad-daily/lib/Part.so+0x33
#6  /usr/lib/x86_64-linux-gnu/libpython2.7.so.1.0(PyEval_EvalFrameEx+0x8541) [0x7fe2869110a1]
#7  /usr/lib/x86_64-linux-gnu/libpython2.7.so.1.0(PyEval_EvalCodeEx+0x86c) [0x7fe286a7816c]
#8  /usr/lib/x86_64-linux-gnu/libpython2.7.so.1.0(PyEval_EvalCode+0x19) [0x7fe2869089d9]
#9  /usr/lib/x86_64-linux-gnu/libpython2.7.so.1.0(PyRun_FileExFlags+0x8e) [0x7fe2869bff7e]
#10  0x7fe286ebb584 in Base::InterpreterSingleton::runFile(char const*, bool) from /usr/lib/freecad-daily/lib/libFreeCADBase.so+0xa4
#11  0x7fe28793467a in Gui::MacroManager::run(Gui::MacroManager::MacroType, char const*) from /usr/lib/freecad-daily/lib/libFreeCADGui.so+0x1da
#12  0x7fe287a6a56e in Gui::PythonEditorView::executeScript() from /usr/lib/freecad-daily/lib/libFreeCADGui.so+0x6e
#13  0x7fe287a6a720 in Gui::PythonEditorView::onMsg(char const*, char const**) from /usr/lib/freecad-daily/lib/libFreeCADGui.so+0x70
#14  0x7fe2878f40e7 in Gui::Application::sSendActiveView(_object*, _object*, _object*) from /usr/lib/freecad-daily/lib/libFreeCADGui.so+0x67
#15  /usr/lib/x86_64-linux-gnu/libpython2.7.so.1.0(PyEval_EvalFrameEx+0x8541) [0x7fe2869110a1]
#16  /usr/lib/x86_64-linux-gnu/libpython2.7.so.1.0(PyEval_EvalCodeEx+0x86c) [0x7fe286a7816c]
#17  /usr/lib/x86_64-linux-gnu/libpython2.7.so.1.0(PyEval_EvalCode+0x19) [0x7fe2869089d9]
#18  /usr/lib/x86_64-linux-gnu/libpython2.7.so.1.0(PyRun_StringFlags+0x76) [0x7fe2869c00d6]
#19  0x7fe286ebad56 in Base::InterpreterSingleton::runString[abi:cxx11](char const*) from /usr/lib/freecad-daily/lib/libFreeCADBase.so+0x66
#20  0x7fe287952830 in Gui::Command::doCommand(Gui::Command::DoCmd_Type, char const*, ...) from /usr/lib/freecad-daily/lib/libFreeCADGui.so+0x130
#21  0x7fe28795722c in Gui::Command::invoke(int) from /usr/lib/freecad-daily/lib/libFreeCADGui.so+0x7c
#22  0x7fe285845f70 in QMetaObject::activate(QObject*, QMetaObject const*, int, void**) from /usr/lib/x86_64-linux-gnu/libQtCore.so.4+0x4d0
#23  0x7fe285d57dc2 in QAction::triggered(bool) from /usr/lib/x86_64-linux-gnu/libQtGui.so.4+0x42
#24  0x7fe285d59113 in QAction::activate(QAction::ActionEvent) from /usr/lib/x86_64-linux-gnu/libQtGui.so.4+0x83
#25  /usr/lib/x86_64-linux-gnu/libQtGui.so.4(+0x5a0fa3) [0x7fe286139fa3]
#26  0x7fe28613a0f4 in QAbstractButton::mouseReleaseEvent(QMouseEvent*) from /usr/lib/x86_64-linux-gnu/libQtGui.so.4+0x74
#27  0x7fe2862000aa in QToolButton::mouseReleaseEvent(QMouseEvent*) from /usr/lib/x86_64-linux-gnu/libQtGui.so.4+0xa
#28  0x7fe285db4930 in QWidget::event(QEvent*) from /usr/lib/x86_64-linux-gnu/libQtGui.so.4+0x2a0
#29  0x7fe285d5e03c in QApplicationPrivate::notify_helper(QObject*, QEvent*) from /usr/lib/x86_64-linux-gnu/libQtGui.so.4+0x8c
#30  0x7fe285d65136 in QApplication::notify(QObject*, QEvent*) from /usr/lib/x86_64-linux-gnu/libQtGui.so.4+0x476
#31  0x7fe2879320f4 in Gui::GUIApplication::notify(QObject*, QEvent*) from /usr/lib/freecad-daily/lib/libFreeCADGui.so+0x54
#32  0x7fe2858318ad in QCoreApplication::notifyInternal(QObject*, QEvent*) from /usr/lib/x86_64-linux-gnu/libQtCore.so.4+0x8d
#33  0x7fe285d6473d in QApplicationPrivate::sendMouseEvent(QWidget*, QMouseEvent*, QWidget*, QWidget*, QWidget**, QPointer<QWidget>&, bool) from /usr/lib/x86_64-linux-gnu/libQtGui.so.4+0x14d
#34  /usr/lib/x86_64-linux-gnu/libQtGui.so.4(+0x249452) [0x7fe285de2452]
#35  0x7fe285de1ce3 in QApplication::x11ProcessEvent(_XEvent*) from /usr/lib/x86_64-linux-gnu/libQtGui.so.4+0x16b3
#36  /usr/lib/x86_64-linux-gnu/libQtGui.so.4(+0x272592) [0x7fe285e0b592]
#37  /lib/x86_64-linux-gnu/libglib-2.0.so.0(g_main_context_dispatch+0x2a7) [0x7fe27e4948a7]
#38  /lib/x86_64-linux-gnu/libglib-2.0.so.0(+0x4ab10) [0x7fe27e494b10]
#39  /lib/x86_64-linux-gnu/libglib-2.0.so.0(g_main_context_iteration+0x2c) [0x7fe27e494bbc]
#40  0x7fe28586220e in QEventDispatcherGlib::processEvents(QFlags<QEventLoop::ProcessEventsFlag>) from /usr/lib/x86_64-linux-gnu/libQtCore.so.4+0x7e
#41  /usr/lib/x86_64-linux-gnu/libQtGui.so.4(+0x272666) [0x7fe285e0b666]
#42  0x7fe28583012f in QEventLoop::processEvents(QFlags<QEventLoop::ProcessEventsFlag>) from /usr/lib/x86_64-linux-gnu/libQtCore.so.4+0x3f
#43  0x7fe285830495 in QEventLoop::exec(QFlags<QEventLoop::ProcessEventsFlag>) from /usr/lib/x86_64-linux-gnu/libQtCore.so.4+0x1b5
#44  0x7fe285836459 in QCoreApplication::exec() from /usr/lib/x86_64-linux-gnu/libQtCore.so.4+0x99
#45  0x7fe2878ead52 in Gui::Application::runApplication() from /usr/lib/freecad-daily/lib/libFreeCADGui.so+0x15e2
#46  freecad-daily(main+0x661) [0x55ad8b2e50e1]
#47  /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xf1) [0x7fe284d603f1]
#48  freecad-daily(_start+0x2a) [0x55ad8b2e633a]
ickby
Postby ickby » Fri Mar 10, 2017 8:53 am
I reportet a bug regarding this functionality quite some time ago, maybe it is the same problem that you hit:
https://tracker.dev.opencascade.org/view.php?id=26295
That functionality is currently exposed in PartDesign pipe tool, you can experiment there to see if your shapes work.
Chris_G
Postby Chris_G » Fri Mar 10, 2017 10:14 am
Hi ickby,
Mmm ... almost 2 years old, and no fix. That's sad.
Thanks
Postby Kunda1 » Fri Mar 10, 2017 2:00 pm
Hi ickby,
Thanks
shoogen was active on their bugtracker and I'm under the impression that is why he got many prvevious OCC bugs implemented in to OCC7.0
We need folks to bump those issues so they get one someones radar
Postby Kunda1 » Fri Mar 10, 2017 2:04 pm
Created and linking issue #2961 to track upstream process.
looo
Postby looo » Sun Mar 12, 2017 2:06 pm
thanks for the information.
I will try to use the suggestion provided by Chris_G.
Btw.: The function I used for the helical extrusion is copied from the scad-wb. So maybe there this feature is also broken...
