Calling a dialog box
davecoventry
Postby davecoventry » Sat Mar 11, 2017 3:23 pm
I've used the example here to generate a dialog box which has 4 fields, the dx, dy, dz and the distance between two points.
It works fine if I input from the python console:
 import dialog
>>> from PySide import QtGui
>>> d = QtGui.QWidget()
>>> d.ui=dialog.Ui_Dialog()
>>> d.ui.setupUi(d,[5,5,10])
>>> d.show()
However, I'm trying to pick 2 points with which to populate the fields in my dialog box.
import FreeCADGui
import math
import dialog
basepoint=None
def pointHandler(val,point):
  global basepoint
  if val==0:
    basepoint=point
  else:
    dx=point.x-basepoint.x
    dy=point.y-basepoint.y
    dz=point.z-basepoint.z
    print "dx=\n",dx
    print "dy=\n",dy
    print "dz=\n",dz
    print math.sqrt(dx*dx+dy*dy+dz*dz)
    d = QtGui.QWidget()
    d.ui.setupUi(d,[dx,dy,dz])
    d.show()
class pointSnapper:
  def __init__(self,val):
    self.point = None
    self.val=val
    FreeCADGui.Snapper.getPoint(callback=self.clicked)
  def clicked(self,point,extra):
    self.point = point
    if self.val==1:
      pointHandler(0,point)
      pointSnapper(2)
    else:
      pointHandler(1,point)
s = pointSnapper(1)
The dialog box doesn't appear, although the correct results are printed to the command shell.
There are no errors printed.
How do I get my dialog box to appear?
~ Dave
triplus
Re: Calling a dialog box
Postby triplus » Sat Mar 11, 2017 5:47 pm
Hi Dave.
You use:
import dialog
But you didn't provide the dialog.py related code. Therefore trying to help would only be related to guessing.
P.S. And note that to avoid any potential module clashes use prefix. Like for example DaveDialog.py as dialog.py is such generic name and it could (likely not) already be in use. ;)
davecoventry
Postby davecoventry » Sat Mar 11, 2017 10:44 pm
Thanks for the response.
The dialog.py file is pretty much the same as the the example I linked to with a few minor modifications.
import FreeCADGui, Part
import DraftTools, WorkingPlane
from pivy.coin import *
import FreeCAD
import math
class Ui_Dialog(object):
  def setupUi(self, Dialog,sizes):
    import FreeCAD as App
    Dialog.setObjectName("Dialog")
    Dialog.resize(264, 231)
    self.label_x = QtGui.QLabel(Dialog)
    self.label_x.setGeometry(QtCore.QRect(40, 70, 59, 14))
    self.label_x.setObjectName("label_x")
    self.label_y = QtGui.QLabel(Dialog)
    self.label_y.setGeometry(QtCore.QRect(40, 100, 59, 14))
    self.label_y.setObjectName("label_y")
    self.label_z = QtGui.QLabel(Dialog)
    self.label_z.setGeometry(QtCore.QRect(40, 130, 59, 14))
    self.label_z.setObjectName("label_z")
    self.label_d = QtGui.QLabel(Dialog)
    self.label_d.setGeometry(QtCore.QRect(40, 150, 59, 14))
    self.label_d.setObjectName("label_d")
    self.Edit_x = QtGui.QLineEdit(Dialog)
    self.Edit_x.setGeometry(QtCore.QRect(120, 60, 113, 22))
    self.Edit_x.setObjectName("Edit_x")
    self.Edit_x.setText(str(sizes[0]))
    self.Edit_y = QtGui.QLineEdit(Dialog)
    self.Edit_y.setGeometry(QtCore.QRect(120, 90, 113, 22))
    self.Edit_y.setObjectName("Edit_y")
    self.Edit_y.setText(str(sizes[1]))
    self.Edit_z = QtGui.QLineEdit(Dialog)
    self.Edit_z.setGeometry(QtCore.QRect(120, 120, 113, 22))
    self.Edit_z.setObjectName("Edit_z")
    self.Edit_z.setText(str(sizes[2]))
    self.Edit_dist = QtGui.QLineEdit(Dialog)
    self.Edit_dist.setGeometry(QtCore.QRect(120, 150, 113, 22))
    self.Edit_dist.setObjectName("Edit_dist")
    self.Edit_dist.setText(str(math.sqrt(sizes[0]*sizes[0]+sizes[1]*sizes[1]+sizes[2]*sizes[2])))
    self.label = QtGui.QLabel(Dialog)
    self.label.setGeometry(QtCore.QRect(60, 20, 59, 14))
    self.label.setObjectName("label")
    self.getpointmode=True
    self.retranslateUi(Dialog)
    QtCore.QMetaObject.connectSlotsByName(Dialog)
  def retranslateUi(self, Dialog):
    Dialog.setWindowTitle(QtGui.QApplication.translate("Dialog", "Dialog", None, QtGui.QApplication.UnicodeUTF8))
    self.label_x.setText(QtGui.QApplication.translate("Dialog", "X Value", None, QtGui.QApplication.UnicodeUTF8))
    self.label_y.setText(QtGui.QApplication.translate("Dialog", "Y Value", None, QtGui.QApplication.UnicodeUTF8))
    self.label_z.setText(QtGui.QApplication.translate("Dialog", "Z Value", None, QtGui.QApplication.UnicodeUTF8))
    self.label_d.setText(QtGui.QApplication.translate("Dialog", "Distance", None, QtGui.QApplication.UnicodeUTF8))
    self.label.setText(QtGui.QApplication.translate("Dialog", "Distance between points", None, QtGui.QApplication.UnicodeUTF8))
On your recommendation, I changed the filename to pt_dialog.py but this has made no difference.
I suppose it's possible that the reason the dialog is not displaying is an error in the pt_dialog.py file, but I would have thought that the fact that the dialog is displayed correctly when called directly from the python panel would indicate that this is unlikely.
~ Dave
triplus
Postby triplus » Sat Mar 11, 2017 11:07 pm
I took a quick look. If i use your work as a base and add a small modification i can get the dialog:
import FreeCADGui
import math
import dialog
basepoint=None
mw = FreeCADGui.getMainWindow()
  global basepoint
  if val==0:
    basepoint=point
  else:
    print "dx=\n",dx
    print "dy=\n",dy
    print "dz=\n",dz
    d = QtGui.QDialog(mw)
    d.show()
class pointSnapper:
    self.point = None
    self.val=val
    self.point = point
    if self.val==1:
      pointSnapper(2)
    else:
s = pointSnapper(1)
Hope this helps you!
davecoventry
Postby davecoventry » Sun Mar 12, 2017 4:05 am
<type 'exceptions.TypeError'>
File "/usr/lib/freecad/Mod/Draft/DraftSnap.py", line 1043, in click
accept()
File "/usr/lib/freecad/Mod/Draft/DraftSnap.py", line 1053, in accept
callback(self.pt,obj)
File "/home/dave/.FreeCAD/Macro/FreeCAD-addons-master/dist.py", line 35, in clicked
File "/home/dave/.FreeCAD/Macro/FreeCAD-addons-master/dist.py", line 21, in pointHandler
d.ui=pt_dialog.Ui_Dialog(mw)
TypeError: object() takes no parameters
OS: Debian GNU/Linux 8.7 (jessie)
Version: 0.16.
Build type: None
Python version: 2.7.9
Qt version: 4.8.6
OCC version: 6.8.0.oce-0.17
import FreeCADGui
import math
import pt_dialog
basepoint=None
  global basepoint
  global mw
  if val==0:
    basepoint=point
  else:
    print "dx=\n",dx
    print "dy=\n",dy
    print "dz=\n",dz
    d = QtGui.QWidget()
    d.show()
class pointSnapper:
    self.point = None
    self.val=val
    self.point = point
    if self.val==1:
      pointSnapper(2)
    else:
s = pointSnapper(1)
~ Dave
triplus
Postby triplus » Sun Mar 12, 2017 1:27 pm
Hi Dave.
I combined all the code you shared and added the small modification i mentioned earlier. Create a new macro and copy/paste the code in it.
import FreeCAD
import math
basepoint=None
  global basepoint
  global mw
  if val==0:
    basepoint=point
  else:
    print "dx=\n",dx
    print "dy=\n",dy
    print "dz=\n",dz
    d.ui=Ui_Dialog()
    d.show()
class pointSnapper:
    self.point = None
    self.val=val
    self.point = point
    if self.val==1:
      pointSnapper(2)
    else:
s = pointSnapper(1)
After run the macro to see what will be the result.
davecoventry
Postby davecoventry » Sun Mar 12, 2017 3:49 pm
It works!
Thanks very much!
~ Dave
triplus
Postby triplus » Sun Mar 12, 2017 4:10 pm
davecoventry wrote:It works!
Thanks very much!
You're welcome.
