Document added in script does not show up in GUI
francoisv2
Postby francoisv2 » Mon Mar 13, 2017 1:07 pm
I am trying to dynamically create a document, add some objects to it, and then launch the GUI. Example script below:
from PySide import QtGui
def main(*args, **kwargs):
    import sys
    from csg.visualization import FreeCADModelViewer
    import FreeCAD as App
    import FreeCADGui as Gui
    app = QtGui.QApplication(sys.argv)
    new_document = App.newDocument("Test")
    App.ActiveDocument = new_document
    # add some data to the active document
    model = FreeCADModelViewer(new_document)
    model.attach('regulator_plate.asm')
    Gui.ActiveDocument = new_document
    # check that objects were added
    print(new_document.Objects)
    Gui.showMainWindow()
    sys.exit(app.exec_())
if __name__ == '__main__':
        main()
The problem is that the document does not appear in the GUI, although (in the console) it is correctly set as App.ActiveDocument. This remains the case even when the document is empty (contain no objects).
Am I missing something?
DeepSOIC
Re: Document added in script does not show up in GUI
Postby DeepSOIC » Mon Mar 13, 2017 1:36 pm
Hi!
I think that you should never assign to App.ActiveDocument, because that doesn't inform FreeCAD that active document has changed. Use App.setActiveDocument() instead. (EDIT: and it shouldn't be necessary either, because any new document automatically becomes active)
Assigning App.ActiveDocument to Gui.ActiveDocument is probably even worse. They are objects of different types.
>>> Gui.ActiveDocument.TypeId
'Base::Persistence' # <-- that's a pretty strange type, IMO. I expected Gui::Document
>>> App.ActiveDocument.TypeId
'App::Document'
francoisv2
Postby francoisv2 » Mon Mar 13, 2017 2:04 pm
Thanks for pointing that out.
I've removed any assigning of active documents, but my document still does not show up in the GUI. However, in the console,
>>> App.listDocuments()
{'Test': <Document object at 0x22fe2a0>}
so it is indeed there.
ulrich1a
Postby ulrich1a » Mon Mar 13, 2017 4:14 pm
At typing in the FreeCAD-Python console the command "new_document = App.newDocument("Test")" the following happens:
>>> App.setActiveDocument("Test")
>>> App.ActiveDocument=App.getDocument("Test")
>>> Gui.ActiveDocument=Gui.getDocument("Test")
And the new document shows up.
You may have to add one of the commands to your script.
Ulrich
