declare a (helper) construction line in python
Leatherman
Postby Leatherman » Wed Mar 15, 2017 11:06 am
sorry for this noob question, but I couldn't find an answer anywhere: How do I declare a (helper) construction line (or other primitive) with python?
Could somebody give me pls an idea?
Regards
Andre
Chris_G
Re: declare a (helper) construction line in python
Postby Chris_G » Wed Mar 15, 2017 2:27 pm
I'm not sure this is what you're looking for ( I don't use it myself ) :
Construction property (here on a Part.Line) :
print(Part.Line.Construction.__doc__)
Defines this geometry as a construction one which
means that it is not part of a later built shape.
Leatherman
Postby Leatherman » Wed Mar 15, 2017 2:56 pm
thank you this is it! Now I assume it's the same with circle or box, just add the .construction? Guess it should be like that.
Great Thread closed, thank you Chris,
regards
Andre
