Name of a solid in a compound - from selection
HoWil
Postby HoWil » Thu Mar 16, 2017 7:36 am
Good morning,
I need to improve the following script which allows for listing all elements below a cursor-click: https://forum.freecadweb.org/viewtopic. ... or#p151950
The goal is to click on e.g. a Face of a Fusion of two Solids and get all elements/objects below the click. I want to list the Faces below the cursor, the Fusion itself, and the two Solids, at least the one below the cursor.
I get the Faces and the Compound from element_list in the script below. The Solids inside the Compound can also be listed.
The only thing I miss is how can I identify these solids. How do I get their Label/Name to select them... in the case below the Label/Name of 's'.
pos = (0, 0) # The compound in question has to be positioned at the lower left corner of the 3D-view-Window !!!!!!!!
element_list = FreeCADGui.ActiveDocument.ActiveView.getObjectsInfo((int(pos[0]), int(pos[1])))
e = element_list[0]
label_object = str(e["Object"]) # the label of e.g. the compound
label_component = str(e["Component"]) # the label of e.g. a face
compound = FreeCAD.ActiveDocument.getObject(label_object)
solids = compound.Shape.Solids
s = solids[0] # How do I identify this solid; how do I get its label???
I also included a min. .fcstd ... please use it as shown in the screenshot.
Element_selector_test_case_min.fcstd
(5.04 KiB) Downloaded 8 times
how to get a label/name of s ??
Screenshot from 2017-03-16 08-32-26.png (224.11 KiB) Viewed 251 times
Thanks in advance,
HoWil
HoWil
Re: Name of a solid in a compound - from selection
Postby HoWil » Thu Mar 16, 2017 7:37 am
Is there maybe also an easier way to to the requested.... find all solids, compounds,... a face/edge belongs to??
BR,
HoWil
mario52
Postby mario52 » Thu Mar 16, 2017 10:28 am
hi
try this macro Macro_FCInfo
mario
Windows 10
Maybe you need a special feature, go into Macros_recipes and Code_snippets. My macros on Gist.github
HoWil
Postby HoWil » Thu Mar 16, 2017 1:37 pm
mario52 wrote:hi
mario
Dear Mario,
Thx for the info but it also only lists the name of the compound and not the solid of which the compound is made of:
FCInfo dialog and FC-Selection-view showing only 'BooleanFragments001' and 'Compound'.
Screenshot from 2017-03-16 14-23-39.png (255.26 KiB) Viewed 218 times
In the dialogs of FEM-mesh-group and FEM-material-assignment one get the info
FEM-mesh-group dialog showing the needed information.
Screenshot from 2017-03-16 14-25-11.png (215.64 KiB) Viewed 218 times
but I do not found the needed information in the code.
BR,
HoWil
DeepSOIC
Postby DeepSOIC » Thu Mar 16, 2017 1:48 pm
Hi!
This problem is very much related to toponaming. OpenCascade does provide this information, and FreeCAD uses it to make face colors go through Boolean operations. However, none of that functionality is exposed to python so far.
mario52
Postby mario52 » Thu Mar 16, 2017 3:22 pm
hi
the text "BooleanFragment001" is long for the textedit try with the mouse in the text edit to see the complete name
the code for this is:
sel = FreeCADGui.Selection.getSelection()
object_Name  = sel[0].Name
App.Console.PrintMessage("object_Name    : "+str(object_Name)+"\n\n")
SubElement = FreeCADGui.Selection.getSelectionEx()
subElementName = Gui.Selection.getSelectionEx()[0].SubElementNames[0]
App.Console.PrintMessage("subElementName : "+str(subElementName)+"\n")
object_Label = sel[0].Label
App.Console.PrintMessage("object_Label   : "+(object_Label)+"\n")
(see Code_snippets)
mario
Windows 10
HoWil
Postby HoWil » Thu Mar 16, 2017 4:49 pm
Dear mario,
It is more about the Solid3 in the BooleanFragments001 than the BF itself :!: The solids are newly named in a e.g. BooleanFragment and that name is needed.
Can you extract Solid3 from the selection in the given example :?:
Attached also the demo file incorporating the BooleanFragments of the Cylinder and the Cube:
Element_selector_test_case_bf.fcstd
(7.02 KiB) Downloaded 5 times
BR,
HoWil
mario52
Postby mario52 » Thu Mar 16, 2017 5:43 pm
hi
There is no object named Solid3
(i have unziped with "Project utility.."
mario
Windows 10
HoWil
Postby HoWil » Thu Mar 16, 2017 6:19 pm
Let me explain it from an other view.
In the attached .fcstd above, there were tow solids 'merged' in a BooleanFragments-operation. This operation yields three! separate Solids since the intersecting domain is seen as new solid. This three solids can be found with the script-snippet from my first post see....
Three solids in the BooleanFragments object.
Screenshot from 2017-03-16 19-14-25.png (174.11 KiB) Viewed 167 times
Here the original two solids were called:
Cylinder, Cube (see the Tree-View in the left part of the screenshot)
And the newly created three solids are listed without names in the Python console in the lower right part of the screenshot.
Now I would need the Labels of these three new solids.
Hope this helps understanding what I need to achieve.
BR,
HoWil
DeepSOIC
Postby DeepSOIC » Thu Mar 16, 2017 7:04 pm
From Boolean fragments, it is technically possible to look up the original, but it requires a bit of rewrite of the tool. BooleanFramgents is just a feature around Part.Shape.generalFuse, which gives the source information along with the three solids. BooleanFragments simply discards that information. All other tools, such as connect, slice, and xor use that information to figure out, which fragments go to result and which are discarded.
