Name of a solid in a compound - from selection
DeepSOIC
Re: Name of a solid in a compound - from selection
Postby DeepSOIC » Mon Mar 20, 2017 7:59 pm
bernd wrote:because the inner could have less volume than the outer
True :oops: . Bounding box diagonal is used in wire sorting for face making, so it should work for solids too.
HoWil
Postby HoWil » Tue Mar 21, 2017 6:57 am
bernd wrote:Just realized the system might not work if a solid is inside another solid, because all elements of the inner solid belong to the outer solid too. I need to try this on the mesh region object.
You maybe consider another test case like a sphere completely inside a box where one not so easily can select a face or edge. This shortcoming was the starting point to write the Element-selector macro.
Here an according file where I would like to select the inner solid as part of the BooleanFragments:
BR,
HoWil
