reliably determine if a shape is 2D.
sliptonic
Postby sliptonic » Sun Mar 19, 2017 3:11 pm
I've got a function that tests if a hole is drillable. It acts differently if it is evaluating a solid object rather than a 2D object. In one case it evaluates faces, in the other it only looks at edges.
I've been looking at the ZLength of the shape boundbox to see if it's greater than 0 but there are cases where a 2D object boundbox meets that criteria.
What's a reliable way to tell if my shape is 2D?
DeepSOIC
Re: reliably determine if a shape is 2D.
Postby DeepSOIC » Sun Mar 19, 2017 4:39 pm
In c++, OCC offers a routine to find plane. AFAIK it uses edges, so it will probably tell you that a sphere is a 2d object. I don't think it is exposed to python...
yorik
Site Admin
Postby yorik » Sun Mar 19, 2017 4:48 pm
DraftGeomUtils.isPlanar(shape) does it.
Basically fin d a normal for the shape (from any 3 non-aligned vertices), th project all other vertices on that normal. If any of them gives any length (ie. it is not strictly perpendicular to the normal), then the shape is not planar.
DeepSOIC
Postby DeepSOIC » Sun Mar 19, 2017 4:53 pm
yorik wrote:Basically fin d a normal for the shape (from any 3 non-aligned vertices), ....
What about circles? They have only 1 vertex...
yorik
Site Admin
Postby yorik » Mon Mar 20, 2017 2:08 pm
yes, but circles will always be planar...
I wonder if it would be possible to have a cyclic (one vertex) spline that is not planar?
Chris_G
Postby Chris_G » Mon Mar 20, 2017 2:54 pm
Hi Yorik,
yorik wrote:I wonder if it would be possible to have a cyclic (one vertex) spline that is not planar?
Yes, it is :
yorik
Site Admin
Postby yorik » Tue Mar 21, 2017 2:56 pm
CQFD :D thanks!
