How to show properties in Property Editor in added order
Son
Postby Son » Mon Mar 20, 2017 5:34 am
I am writing a python script to create an I-beam. It works so far. However in the script I added the properties in a certain order (please see code below) for convenience and hoped that they would show exactly like that in the Property Editor but apparently they are listed in alphabetical order (please see attached picture). Is there any way it can be scripted for the properties to show in their added order?
import Part
class IShape:
 def __init__(self,obj):
   obj.Proxy = self
   obj.addProperty("App::PropertyFloat","Length").Length = 60.0
   obj.addProperty("App::PropertyFloat","Depth").Depth = 44.0
   obj.addProperty("App::PropertyFloat","Flange Width").Flange_Width = 16.0
   obj.addProperty("App::PropertyFloat","Web Thickness").Web_Thickness = 1.0
   obj.addProperty("App::PropertyFloat","Flange Thickness").Flange_Thickness = 1.75
 def execute(self,obj):
FreeCAD Info:
Version: 0.16.6706 (Git)
Branch: releases/FreeCAD-0-16
Python version: 2.7.8
OCC version: 6.8.0.oce-0.17
Site Admin
Re: How to show properties in Property Editor in added order
Postby wmayer » Mon Mar 20, 2017 9:31 am
No, this is currently impossible because the alphabetical order is caused by using a std::map in https://github.com/FreeCAD/FreeCAD/blob ... rty.h#L136
A std::map has the property to sort all elements by the key value and for a string as key it means they are sorted alphabetically.
microelly2
Postby microelly2 » Mon Mar 20, 2017 10:20 am
obj.addProperty("App::PropertyBool","noExecute" ,"Base")
obj.addProperty("App::PropertyInteger","Degree","Base").Degree=3
obj.addProperty("App::PropertyLink","Meridians","RibCage")
obj.addProperty("App::PropertyInteger","RibCount","RibCage").RibCount=10
obj.addProperty("App::PropertyInteger","MeshUCount","Mesh").MeshUCount=5
obj.addProperty("App::PropertyInteger","MeshVCount","Mesh").MeshVCount=5
obj.addProperty("App::PropertyLink","ribtemplateSource","Spreadsheet")
obj.addProperty("App::PropertyLink","backboneSource","Spreadsheet")
obj.addProperty("App::PropertyBool","externSourcesOff" ,"Spreadsheet")
A workaround is to group the properties.
Son
Postby Son » Mon Mar 20, 2017 3:54 pm
Thank you all for your help.
microelly2: I will try grouping the properties when I get home.
Son
Postby Son » Tue Mar 21, 2017 5:33 am
The properties are organized better with groups. They are still sorted alphabetical within a group so I made up some names to help with that, a little awkward but they'll do for now. 8-)
   lenGrpName = "Beam Length"
   obj.addProperty("App::PropertyFloat","Length",lenGrpName).Length = 60.0
   sxnGrpName = "Cross Section"
   obj.addProperty("App::PropertyFloat","Depth",sxnGrpName).Depth = 44.0
   obj.addProperty("App::PropertyFloat","FlangeWidth",sxnGrpName).FlangeWidth = 16.0
   obj.addProperty("App::PropertyFloat","ThicknessWeb",sxnGrpName).ThicknessWeb = 1.0
   obj.addProperty("App::PropertyFloat","ThicknessFlange",sxnGrpName).ThicknessFlange = 1.75
