makeFilledFace crashing FreeCAD
Re: makeFilledFace crashing FreeCAD
IIRC the developer versions are compiled with debug symbols. However, if I try to generate a backtrace I get the error (whole message in one line):
xcrun: error: invalid active developer path (/Library/Developer/CommandLineTools), missing xcrun at: /Library/Developer/CommandLineTools/usr/bin/xcrun
xcrun is installed, but it is in the directory /usr/bin/
Any ideas how to create a backtrace on the mac?
BTW: the crash does not occur if I run FreeCAD in the virtual Ubuntu running on the Mac.
Founder
Post by wmayer »
nmt wrote:Sorry, I am not set up to compile FreeCAD on my Mac. If someone can point me to an executable that has already been compiled with the debug flag, I can give it a try.
You don't necessarily need debug symbols. Usually it suffices to just run it in the debugger which then shows the cascaded function call upon the crash. This also works with a non-debug build but only if the tool strip hasn't been applied on the binaries after the compilation.
nmt
Post by nmt »
They have confirmed it on MantisBT and they have the traceback there: https://freecadweb.org/tracker/view.php?id=2985#c8716
Confirmed using 10653 from GitHub on both Qt4 and Qt5. Did not crash when compiled locally (i.e. Debug build on 10.12) so traceback is from the GitHub/Travis build on 10.10.
Post by Kunda1 »
As @nmt mentioned bug has been confirmed. Backtrace provided by @bblacey is in https://freecadweb.org/tracker/view.php?id=2985#c8716
Post by Kunda1 »
wmayer wrote:IMO, this must be a bug in occ7.1.0 under macOS because with only this configuration this issue appeared so far.
(from https://freecadweb.org/tracker/view.php?id=2985#c9666 )
