No easy way to get start and end points of straight edge?
DeepSOIC
Post by DeepSOIC »
Hi!
There used to be an easy way to obtain coordinates of endpoints of a linear edge:
edge.Curve.StartPoint
edge.Curve.EndPoint
Now they are gone. So I see three ways of doing it now, which are quite a bit uglier:
edge.Vertexes[0].Point
edge.Curve.value(edge.FirstParameter)
edge.valueAt(edge.FirstParameter)
The first one is ugly because I'm not sure if Vertexes[0] is always the vertex that corresponds to FirstParameter. The second and the third ones are substantially longer code, and it feels like it will do unnecessary computations under the hood (probably doesn't matter).
So I ask: give me a straightforward way to convert a linear edge into a LineSegment, not Line.
Chris_G
Re: No easy way to get start and end points of straight edge?
Post by Chris_G »
edge.toNurbs().Edges[0].Curve.StartPoint
edge.toNurbs().Edges[0].Curve.EndPoint
:mrgreen:
DeepSOIC
Post by DeepSOIC »
Chris_G wrote:
:mrgreen:
:lol:
DeepSOIC
Post by DeepSOIC »
I just patched up Lattice's LinearArray and PolarArray that were broken because of this.
Founder
Post by wmayer »
No that's not correct. With the old behaviour where from an edge a LineSegment instead of an infinite Line was returned it's not necessarily true that the segment's start point is coincident the edge's start vertex because it also depends on the edge's orientation.
A reliable way to determine the start vertex is to check its orientation: if it is set to forward then it's the start vertex, if it's set to reversed then it's the end vertex.
For more information have a look at this thread: https://forum.freecadweb.org/viewtopic.php?t=18204
Based on Yorik's example I have put together this code snippet which must be tested with 0.16 (or the setting to activate the old behaviour)
b = Part.makeBox(2,2,2)
b.Edges[2].Orientation # => Reversed
b.Edges[2].Curve # => <Line (0,2,0) (0,2,2) >
b.Edges[2].Vertexes[0].Point, b.Edges[2].Vertexes[0].Orientation # => (Vector (0.0, 2.0, 2.0), 'Forward')
b.Edges[2].Vertexes[1].Point, b.Edges[2].Vertexes[1].Orientation # => (Vector (0.0, 2.0, 0.0), 'Reversed')
In this case the line's start point is (0,2,0) but the edge's start vertex is (0,2,2)
Founder
Post by wmayer »
The class TopExp of OCC provides two static methods FirstVertex and LastVertex to get an edge's first or last vertex. The methods accept a second parameter to take the edge's orientation into account or not.
  //! Returns the Vertex of orientation FORWARD in E. If
  //! there is none returns a Null Shape.
  //! CumOri = True : taking account the edge orientation
  Standard_EXPORT static TopoDS_Vertex FirstVertex (const TopoDS_Edge& E, const Standard_Boolean CumOri = Standard_False);
  //! Returns the Vertex of orientation REVERSED in E. If
  Standard_EXPORT static TopoDS_Vertex LastVertex (const TopoDS_Edge& E, const Standard_Boolean CumOri = Standard_False);
I think the very best would be to add these two methods to our topo edge Python wrapper.
DeepSOIC
Post by DeepSOIC »
wmayer wrote:The class TopExp of OCC provides two static methods FirstVertex and LastVertex to get an edge's first or last vertex. The methods accept a second parameter to take the edge's orientation into account or not.
Sounds good to me :D But for Lattice, I am sticking to edge.valueAt(edge.FirstParameter), because I want to keep supporting FC v0.16.
damian
Post by damian »
edge.firstVertex(True)
edge.lastVertex(True)
very useful
