Unfortunately, removing opencv-highgui without python-opencv is not possible.highgui
Experimental Qt backend for OpenCV has been added as a result of GSoC 2010 project, completed by Yannick Verdie. The backend has a few extra features, not present in the other backends, like text rendering using TTF fonts, separate "control panel" with sliders, push-buttons, checkboxes and radio buttons, interactive zooming, panning of the images displayed in highgui windows, "save as" etc. Please, check the youtube videos where Yannick demonstrates the new features: http://www.youtube.com/user/MrFrenchCookie#p/u
The new API is described here: http://opencv.itseez.com/modules/highgu ... tions.html To make use of the new API, you need to have Qt SDK (or libqt4 with development packages) installed on your machine, and build OpenCV with Qt support (pass -DWITH_QT=ON to CMake; watch the output, make sure Qt is used as GUI backend)
16-bit and LZW-compressed TIFFs are now supported.
You can now set the mode for IEEE1394 cameras on Linux.
OpenCV closes my FreeCAD
Re: OpenCV closes my FreeCAD
I had a look to the changelog of OpenCV and it mentions there Qt support of the highgui package
- microelly2
We do not realy need cv2 for the shoe project (at the moment), so I have replaced the one method from cv2 by some code.wmayer wrote: Unfortunately, removing opencv-highgui without python-opencv is not possible.
But building FreeCAD around QT5 is still possible isn't it?Unfortunately, removing opencv-highgui without python-opencv is not possible.
Thank you for your advice
Andre
wmayer wrote:No it looks you have installed the correct package. But I wonder where is the file cv2.py (or cv2.so) is located. To find this out open a terminal and start python and then enter:Code: Select all
import cv2 cv2.__file__
andre@Andre-PC:~$ python
Python 2.7.12 (default, Nov 19 2016, 06:48:10)
[GCC 5.4.0 20160609] on linux2
Type "help", "copyright", "credits" or "license" for more information.
>>> import cv2
>>> cv2.__file__
'/usr/local/lib/python2.7/dist-packages/cv2.so'
- microelly2
I have installed a newer version of cv2 and it works fine for me:
steps from :
http://docs.opencv.org/2.4/doc/tutorial ... stall.html
1. downloaded: opencv-2.4.13.zip von http://opencv.org/releases.html
2. unzipped to opencv-2.4.13
$ cd opencv-2.4.13
$ mkdir BUILDDIR
$ cd BUILDDIR
$ cmake ..
$ make
# taks some minutes ...
$ sudo make install
$ python
Python 2.7.6 (default, Oct 26 2016, 20:30:19)
[GCC 4.8.4] on linux2
>>> import cv2
>>> cv2
<module 'cv2' from '/usr/local/lib/python2.7/dist-packages/cv2.so'>
>>> cv2.__version__
'2.4.13'
no crash, methods work in FreeCAD.
steps from :
$ cd opencv-2.4.13
$ mkdir BUILDDIR
$ cd BUILDDIR
$ cmake ..
$ make
$ sudo make install
$ python
>>> import cv2
>>> cv2
>>> cv2.__version__
'2.4.13'
It didn't work for me. Here is the log file from my terminal:
https://www.dropbox.com/s/sqcb8us1htd6s ... lease?dl=0
It shows no errors on installation, but finally with "import CV2" in python, it says no module cv2. Same with FreeCAD (which is certainly the idea of this project here). As a none experienced user, I think it should only my handling error, kindly advice me on this final step.
Regards
Andre
Regards
Andre
-- Up-to-date: /usr/local/python/2.7/cv2.so
okay, it says "command not found"looo wrote:To me it seems likecv is installed to a wrong location.Code: Select all
I have never done cmake installation before.
Pls advice,
regards
What other libraries are installed there?
Also you can show the output of sys.path
In python console:
ls /usr/local/python/2.7
In python console:
import sys
sys.path
I have to admit that I really don't understand what is going on. May be somebody can make out something out of this.looo wrote:What other libraries are installed there?Code: Select all
Also you can show the output of sys.pathCode: Select all
ls /usr/local/python/2.7 cv2.so
In python console:Code: Select all
import sys sys.path
import sys >>> sys.path ['', '/usr/lib/python2.7', '/usr/lib/python2.7/plat-x86_64-linux-gnu', '/usr/lib/python2.7/lib-tk', '/usr/lib/python2.7/lib-old', '/usr/lib/python2.7/lib-dynload', '/usr/local/lib/python2.7/dist-packages', '/usr/lib/python2.7/dist-packages', '/usr/lib/python2.7/dist-packages/PILcompat', '/usr/lib/python2.7/dist-packages/gtk-2.0']
Regards
Andre
