Expression Placement (solved)
user1234
Post by user1234 »
Hello!
Is there a way to get the expression from the placement like this pseudocode?
obj = FreeCADGui.Selection.getSelection()
pos = obj[0].getExpression(Base, Placement.Position.x)
obj[1].setExpression(pos)
Always when i try something like 'getExpression' or similar FreeCAD says: 'FeaturePython' object has no attribute 'getExpression'.
I did not find anything in the in the documentation or in the forum seach.
Setting the expression from the placement is no problem with setExpression().
Thanks for helping.
Greetings user1234
Edit: I have forgotten the version:
OS: Debian GNU/Linux 8.7 (jessie)
Version: 0.17.10893 (Git)
Build type: Debug
Hash: a75a98ef279e9e067abf5cef3a6de6f09fba2c94
Python version: 2.7.9
Qt version: 4.8.6
OCC version: 7.1.0
eivindkvedalen
Re: Expression Placement
Post by eivindkvedalen »
user1234 wrote:Hello!
You can get all registered expressions using e.g
expressions = obj[0].ExpressionEngine
This wlll give you an array of tuples that you can search through. Not the nicest interface, but possible to do at least...
Eivind
user1234
Post by user1234 »
This was really fast!!!
Thanks for the help!
