permanet setting of pathes to extern modules
microelly2
Post by microelly2 »
I have installed freecad on windows 7 and cv2
The testcase is running
import sys
sys.path.append('E:\\opencv\\build\\python\\2.7\\x64')
import cv2
fn='E:\\kscan3d\\4.jpg'
img=cv2.imread(fn)
cv2.imshow(fn,img)
Is there a way to add the path to the python binding of cv2 permanently?
like
FreeCAD.ParamGet(' :?: PYTHON SEARCH PATH :?: ').GetString("#1",'E:\\kscan3d\\4.jpg')
It would be nice to have the opportunity to add more extern modules somewhere in the configuration settings.
Having such a functionality we can install more and different versions (for example for cv2, networkx, ..) and switch between them
mario52
Re: permanet setting of pathes to extern modules
Post by mario52 »
hi
normally with Windows
Propriétés système > Paramètres Systeme avancé > Variables d'environnement > Variables système Path ( ...... ; my new path)
(sorry french)
mario
looo
Post by looo »
maybe a user-startup-file would be a good idea? Something like .bashrc or .pythonrc. As a workaround you can use a startupMod (create file: .FreeCAD/Mod/startUp/Init.py and place the sys.path modifications there)
Maybe someone can report the problem with cv2 install-dir to the developers of cv2?
microelly2
looo wrote:maybe a user-startup-file would be a good idea? Something like .bashrc or .pythonrc. As a workaround you can use a startupMod (create file: .FreeCAD/Mod/startUp/Init.py and place the sys.path modifications there)
This is the idea I will follow, it works for portable installations and can handle multiple versions and 32/64 bit in parallel.
What problem do you think :?:
+mario52 thanks for the tipp but I need a more flexible solution.
looo
Post by looo »
microelly2 wrote:What problem do you think :?:
cv2 installs the python-bindings to a wrong directory...
crobar
Post by crobar »
I solved the same problem by creating a new wokbench called Run Startup Script, which you can do by putting the following code in a file in .FreeCAD/Mod/Run_Startup
class RunStartupWorkbench (Workbench):
    # Icon generated using by converting linearDimension.svg to xpm format using Gimp
    Icon = '''
/* XPM */
static char * linearDimension_xpm[] = {
"32 32 10 1",
"       c None",
".      c #000000",
"+      c #0008FF",
"@      c #0009FF",
"#      c #000AFF",
"$      c #00023D",
"%      c #0008F7",
"&      c #0008EE",
"*      c #000587",
"=      c #000001",
    MenuText = 'Run Startup Script'
    def Initialize(self):
        FreeCADGui.doCommand("execfile('/home/rcrozier/.FreeCAD/startup.FCMacro')")
Gui.addWorkbench(RunStartupWorkbench())
If you then make this the default startup workbench it will run whatever you put in startup.FCMacro referenced toward the end in the python interpreter every time you start FreeCAD.
