Does anyone know how to mace a circle with:
DraftGeomUtils.circleFrom1tan2pt ?
The python help doesn't indicate type or units:
circleFrom1tan2pt(tan1, p1, p2)
Is tan1 a line or point or angle? Degrees or radians? Is it referring to the angle at p1 or p2?
Are p1 and p2 supposed to be vectors?
I've tried:
line, vector, vector
angle rad, vector, vector
angle deg, vector, vector
All to no avail.
The command fails with no error messages.
Thank you much.
circleFrom1tan2pt help?
- wandererfan
Re: circleFrom1tan2pt help?
I've never used it, but the source is:
I'd guess (edge,vector,vector).
wf
def circleFrom1tan2pt(tan1, p1, p2):
if (geomType(tan1) == "Line") and isinstance(p1, FreeCAD.Vector) and isinstance(p2, FreeCAD.Vector):
return circlefrom1Line2Points(tan1, p1, p2)
wf
Since it says "geomType" I was wondering if there any chance that its wanting Lines and points rather than Edges and vertices?wandererfan wrote:I've never used it, but the source is:I'd guess (edge,vector,vector).Code: Select all
def circleFrom1tan2pt(tan1, p1, p2): if (geomType(tan1) == "Line") and isinstance(p1, FreeCAD.Vector) and isinstance(p2, FreeCAD.Vector): return circlefrom1Line2Points(tan1, p1, p2)
wf
Jim
- wandererfan
Don't think so. It doesn't like Draft Features.jmaustpc wrote:Since it says "geomType" I was wondering if there any chance that its wanting Lines and points rather than Edges and vertices?
>>> l = App.ActiveDocument.Line
>>> p = App.ActiveDocument.Point
>>> p1 = App.ActiveDocument.Point001
>>> x = DraftGeomUtils.circleFrom1tan2pt(l,p,p1)
>>> print x
None
All those circle functions at the end of DraftGeomUtils were half-implemented a long time ago by a guy who never totally finished the job... so i'm afraid several are not functionning properly
