Screw Maker
Re: Screw Maker
I'd like to make ISO4035-like M5 nut 1 mm long unfortunatelly it has fixed lenght of 2.5 mm. "Nominal lenght" value doesn't work unfortunatelly. Can anyone answer how to add a custom nut to list?
OK, I've just re-scaled it successfully. An easy solution.
Re: Screw Maker
Apologies to post in this thread.
Do i see correct i can use this macro to create tapped holes and screws?
And this is the latest screw creating macro to do that?
http://www.freecadweb.org/wiki/index.ph ... w_maker1_2
Re: Screw Maker
Hello, I love this macro but I needed to have left handed threads so I've modified the code to implement it with a checkbox.
Hope you like it and if there is any bugs, feel free to reply with the error so I can modify the code to fix it.
UPDATE : After trying all the screw types I saw I forgot some so it's been fixed
Re: Screw Maker
I'm Daniel from Germany and this is my first post here.
Since now I have the Screw Maker Macro and I like it very much.
I want to creat a new ISO 7380 Screw with a flat Head. Is this possible?
Thanks a lot
Daniel
Thanks a lot
Daniel
Re: Screw Maker
Are you using the version posted here: memberlist.php?mode=viewprofile&u=1928Daniel3d wrote:I want to creat a new ISO 7380 Screw with a flat Head. Is this possible?
This version has ISO 7380 Screws.
Ulrich
Re: Screw Maker
Yes I use it and I also found the ISO 7380 screws but I have to make a Head with a bigger Radius but flat, like in the picture.
I think its Not easy to creat a new Screw in the macro right?
Daniel
Daniel
- IMG_2106.JPG (17.91 KiB) Viewed 2628 times
Re: Screw Maker
This depends on the type of the screw.Daniel3d wrote:I think its Not easy to creat a new Screw in the macro right?
I programmed only screws, which are defined by an official standard. It will be an endless task otherwise.
The screws on the picture look like something different than ISO 7380. They have a diameter of the shank much bigger than the thread. Exist a standard for these type of screws?
Ulrich
Re: Screw Maker
That seems to be a special locating screw, the german system DIN 173 describes screws of that kind, although they don't have such a big diameter for the head. ISO 7379 is similar (shoulder screws) but they have a hexagon head.
Re: Screw Maker
@ ulrich1a: Really great screw maker makro .... WOW !!!!
The metric iso threads are (unfortunately) not very useful for 3d printed threads.
Therefore i am using my customized thread profile which works pretty well and functional.
The picture shows custom M24 inner thread with 5mm pitch.
How is it possible to generate such custom thread profile with your script?
I want to generate different size and lenght with ISO head.
Would be great if you could help me! THANKS
- freecad_thread_02.jpg (30.02 KiB) Viewed 2520 times
- freecad_thread_01.jpg (93.31 KiB) Viewed 2520 times
Re: Screw Maker
Threads for 3d printers, I have been thinking that all day. Trying to fudge something out of screwmaker right now... really need a thread to hold a spindle together. Wish the I was capable of coding such a thing.
Is 2.0 of the latest version of screwmaker?
Thanks
Thanks
