[Closed]Test Create ArchRebar2 Object
chakkree
Re: Test Create ArchRebar2 Object
Post by chakkree »
Single Line Mode with dimension. Test for find idea.
Next step, create BS shape codes
  Test Create DWire for rebar axis ,
     for concept design of scripted object in future.
  check basic rebar shape code.
  27 Aug 2016
import Part
import Draft
from FreeCAD import Vector , Placement
def CreateStraightBarHook(A=1000 ,placement = None):
    D = +6*12
    L1 = 4*12
    pt1 = Vector(D/2.0 + L1,0,D)
    pt2 = Vector(0,0,D)
    pt3 = Vector(0,0,0)
    pt4 = Vector(A,0,0)
    pt5 = Vector(A,0,D)
    pt6 = Vector(A-D/2.0 - L1,0,D)
    points = [pt1,pt2,pt3,pt4,pt5,pt6]
    axisRebar1 = Draft.makeWire(points,closed=False,face=False,support=None)
    #axisRebar1.FilletRadius = D/2.0         # Eroor <class 'Part.OCCError'>: Both points are equal
    axisRebar1.FilletRadius = D/2.0 - D*0.000001  # tip for prevent error <class 'Part.OCCError'>: Both points are equal
    #axisRebar1.setExpression('FilletRadius', u'+6 * 12 / 2.0')
    #axisRebar1.ViewObject.LineColor = (0.00,1.00,1.00)
    if placement: axisRebar1.Placement=placement
    # ****** find new algorithm for position of Dimension with object
    FreeCAD.DraftWorkingPlane.alignToPointAndAxis(Vector(0,0,0), Vector(0,-1,0), 0.0) # XZ plane
    ptDim1 = Vector(A/2,0,-100)
    Dim1 = Draft.makeDimension(pt3 , pt4 , ptDim1)
    Dim1.Direction = (1.00, 0.00, 0.00)
    Dim1.ViewObject.FontSize = 50
    Dim1.ViewObject.ArrowSize =10
    Dim1.ViewObject.ArrowType = "Arrow"
    FreeCAD.DraftWorkingPlane.alignToPointAndAxis(Vector(0,0,0), Vector(0,0,1), 0.0)
    return axisRebar1
def CreateLShape(A=1000,B=300):
    pt1 = Vector(0,0,0)
    pt2 = Vector(A,0,0)
    pt3 = Vector(A,0,B)
    points = [pt1,pt2,pt3]
    axisRebar1.FilletRadius = 50
    return axisRebar1
#CreateLShape()
rebar1 = CreateStraightBarHook()
FreeCAD.ActiveDocument.recompute()
placement2 = Placement()
placement2.Base.x = 1500
createBSShape01 =  CreateStraightBarHook
rebar2 = createBSShape01(placement=placement2)
Msg('rebar1 length = {}\n'.format(rebar1.Length) )
chakkree
Post by chakkree »
Try to create rebar in FreeCAD like Reinforcment Example from @bernd
Only Rebar in a footing. Not included piers. Test for find idea.
Use DWire for represent rebar in single mode.
     from bernd Example, Footing
     http://forum.freecadweb.org/viewtopic.php?f=18&t=17061#p135030
     27 Aug 2016
import Part
import Draft
def CreateRebar_01(A=540, B=1440 , dia = 12 ,placement = None):
    D = +6*dia
    pt1 = Vector(0,0,0)
    pt2 = Vector(0,0,A)
    pt3 = Vector(B,0,A)
    pt4 = Vector(B,0,0)
    points = [pt1,pt2,pt3,pt4]
    return axisRebar1
def CreateRebar_01_Up(A=540, B=1440 , dia = 12 ,placement = None):
    D = +6*dia
    pt1 = Vector(0,0,A)
    pt2 = Vector(0,0,0)
    pt3 = Vector(B,0,0)
    pt4 = Vector(B,0,A)
    return axisRebar1
def  CreateRebar_02(A=400, B=3900 , dia = 18 ,placement = None):
    D = +6*dia
    pt1 = Vector(0,0,A)
    pt2 = Vector(0,0,0)
    pt3 = Vector(0,B,0)
    axisRebar1.ViewObject.LineColor = (0.00,0.00,1.00)
    return axisRebar1
def  CreateRebar_02_2(A=400, B=3900 , dia = 18 ,placement = None):
    D = +6*dia
    pt1 = Vector(0,0,A)
    pt2 = Vector(0,0,0)
    pt3 = Vector(0,-B,0)
    return axisRebar1
def  CreateRebar_03(A=400, B=5250 , dia = 12 ,placement = None):
    D = +6*dia
    pt1 = Vector(0,0,-A)
    pt2 = Vector(0,0,0)
    pt3 = Vector(0,B,0)
    axisRebar1.ViewObject.LineColor = (1.00,0.00,1.00)
    return axisRebar1
def  CreateRebar_03_2(A=400, B=5250 , dia = 12 ,placement = None):
    D = +6*dia
    pt2 = Vector(0,0,0)
    return axisRebar1
if __name__=="__main__":
    concrete1 = Part.makeBox(1500,7000,600)
    Part.show(concrete1)
    #concrete1.ViewObject.Transparency = 50
    #concrete1.ViewObject.ShapeColor = (0.67,1.00,0.00)
    dia = 12
    Spacing = (7000-2*50)/(35-1)
    z = 30
    for i in range(0,35):
        placement1 = Placement()
        placement1.Base = Vector(30,50+i*Spacing,z)
        bar = CreateRebar_01(placement=placement1)
        placement2.Base = Vector(30,50+i*Spacing+dia,z)
        bar = CreateRebar_01_Up(placement=placement2)
    dia = 18
    Spacing = (1500-2*50)/(7-1)
    z = 30+12/2+18/2
    for i in range(0,7):
        placement1.Base = Vector(50+i*Spacing,30,z)
        bar = CreateRebar_02(placement=placement1)
    dia = 18
    z = 30+12/2+18/2
        placement1.Base = Vector(50+i*Spacing+dia,7000-30,z)
        bar = CreateRebar_02_2(placement=placement1)
    dia = 12
    z = 600-30-12
        placement1.Base = Vector(50+i*Spacing+dia,30,z)
        bar = CreateRebar_03(placement=placement1)
        placement1.Base = Vector(50+i*Spacing,7000-30,z)
        bar = CreateRebar_03_2(placement=placement1)
Combine_Footing_01.FCStd
(100.62 KiB) Downloaded 44 times
IFC file form benrd is very useful and file size very small. only 159 kb can represent a hundread of rebar.
saso
Post by saso »
chakkree wrote:
yorik wrote: I have another (better) idea: Let's make the rebar1 a sub-case of rebar2.
Maybe create a new toolbar in ArchWorkbench,"Arch Rebar tool"?
IMO it could be a good moment to start to think about an Structure WB. For sure in the future structure should get big and powerful enough to have its own WB.
yorik
Founder
Post by yorik »
Can you share the ifc file too? Curious to have a look at it...
chakkree
Post by chakkree »
@yorik I got the IFC file from this topic(FEM/Automation in Design).
viewtopic.php?f=18&t=17061#p134959
This is direct link to file reinforcement.zip (download/file.php?id=25870)
The Zip file contain 3 files.
1. reinforcement--drawing.pdf
2. reinforcement--material_bill.pdf
3. reinforcement--model.ifc -- 159 kb
When open the ifc file, the first it can see as a mass model of concrete. If hide Foontings and Columns. The reinforcement will appear. The rebars are inside the concrete.
reattach only ifc file and many thank to bernd.
(158.23 KiB) Downloaded 53 times
yorik
Founder
Post by yorik »
Oh ok thanks! I thought you generated this IFC file from FreeCAD, I didn't remember the files from Bernd's post :)
In any case this is interesting... I had a better look now, in IFC it works like this:
- An IfcPolyline represents the path
- An IfcSweptDiskSolid creates a solid by sweeping a disk along the path
- An IfcMappedRepresentation shares that solid between several objects (with a different placement for each)
- An IfcReinforcingBar is created for each mapped representation.
This gives a pretty compact file! The only "heavy" data is the polyline, which appears only once for each type of rebar...
There are also sets of properties which are defined once for each rebar type, and associated with each IfcReinforcingBar.
We should definitely add code to our IFC exporter to export rebars like that -> issue #2684
bernd
Post by bernd »
yorik wrote:We should definitely add code to our IFC exporter to export rebars like that -> issue #2684
+1 :D
Have you seen the attribute Position Number. This defines the number of the rebar shape inside the model. This rebar shape could be on different places. All have the same Position number.
Guys if you are interested. I could provide more ifc of rebars and concrete components?! I have hundreds around and we do new ones every day ...
BTW: I was especially proud of the one posted because it was done by myself. Normally I only do sketches by pen and paper and the designer does the model. But once no designer was available and I had to do the model and drawing by myself.
yorik
Founder
Post by yorik »
bernd wrote:Have you seen the attribute Position Number. This defines the number of the rebar shape inside the model. This rebar shape could be on different places. All have the same Position number.
Oho, no, I hadn't noticed. That's good feature...
In a more general way, I'm still not satisfied with the way we handle IFC properties. So far either (my first option) they are stored as a dictionary, or (rockn's work) as a spreadsheet. None are really perfect I think.
Inserting a new property in the FreeCAD object for each IFC property might be a solution, why not, after all? We could also, I think, make the property groups "foldable". Another, would be to create a new kind of property, that can group several IFC properties into one, a bit like they did for the sketcher datums...
bernd
Post by bernd »
This Position number should surely be a FreeCAD property of a rebar shape.
yorik wrote:In a more general way, I'm still not satisfied with the way we handle IFC properties. So far either (my first option) they are stored as a dictionary, or (rockn's work) as a spreadsheet. None are really perfect I think.
Me neiter, thus +1 !
yorik wrote:Inserting a new property in the FreeCAD object for each IFC property might be a solution, why not, after all? We could also, I think, make the property groups "foldable". Another, would be to create a new kind of property, that can group several IFC properties into one, a bit like they did for the sketcher datums...
One property for each IFCPorperty could get huge. I have IFC with dozens of properties.
What I do for my own: Save each PropertySet in a dictionary. For the most important properties, the one I need to access afterwards, I make a FreeCAD property but not during Import. It works but I'm not satisfied with this either.
Mhh but the grouping and folding stuff like datums sounds interesting …
yorik
Founder
Post by yorik »
One of these days I'll anyway make a test if adding hundreds of properies to objects has any impact on performance, just so we know...
