[Closed]Test Create ArchRebar2 Object
chakkree
Re: Test Create ArchRebar2 Object
Post by chakkree »
OK! Fixed! Now it can work corectly(I think :D ) on FreeCAD 0.16 and FreeCAD 0.17
Part.__sortEdges__(spath.Edges) is the key.
Next Step, I'll try to create more shape of rebar.
   ArchRebar2.py
import ArchCommands,ArchComponent,FreeCAD
from FreeCAD import Vector , Placement
import Draft
import DraftGeomUtils , DraftVecUtils
from math import cos , radians
class _Rebar(ArchComponent.Component):
    def __init__(self,obj):
        ArchComponent.Component.__init__(self,obj)
        obj.addProperty("App::PropertyDistance","diameter","Rebar","The diameter of this rebar")
        obj.addProperty("App::PropertyDistance","Length","Rebar","The Length of this rebar")
        obj.addProperty("App::PropertyString","ShapeCode","Rebar","The Shape code of this rebar")
        obj.setEditorMode("Length", 1) # read-only
        obj.setEditorMode("ShapeCode", 1) # read-only
        obj.Role = ['Rebar']
        self.Type = "Rebar"
        #obj.diameter = ['6 mm' , '9 mm' , '12 mm']
    def getProfile(self,obj,noplacement=True):
        return []
    def getExtrusionVector(self,obj,noplacement=True):
        return FreeCAD.Vector()
    def setShapeCode(self , ShapeCode):
        pass
    def execute(self,obj):
        if self.clone(obj):
            return
        dia = obj.diameter
        R = 5*dia /2.
        points = []
        lines = []
        for i in range(1, len(points)):
            lines.append(Part.Line(points[i],points[i-1]))
        spath = Part.Shape(lines)
        edge1 = Part.__sortEdges__(spath.Edges)
        wpath  = Part.Wire(edge1)
        wire = Part.Wire(wpath)
        wire = DraftGeomUtils.filletWire(wire,R)
        bpoint = points[0]
        bvec = points[1].sub(points[0]).normalize()
        circle = Part.makeCircle(dia/2,bpoint,bvec)
        circle = Part.Wire(circle)
        bar = wire.makePipeShell([circle],True,False,2)
        shapes = []
        shapes.append(bar)
        obj.Shape = bar
class _Rebar_U_shape(_Rebar):
        _Rebar.__init__(self,obj)
        obj.addProperty("App::PropertyDistance","A","Rebar","The A length of this rebar")
        obj.addProperty("App::PropertyDistance","B","Rebar","The B length of this rebar")
        obj.ShapeCode="00"
        if self.clone(obj):
            return
        pl = obj.Placement
        dia = obj.diameter
        A = obj.A
        B = obj.B
        R = 5*dia /2.
        #R = 0
        import Part
        points = []
        points.append(Vector(0,0,A))
        points.append(Vector(0,0,0))
        points.append(Vector(B,0,0))
        points.append(Vector(B,0,A))
        for i in range(0, len(points)):
            Msg(points[i])
            Msg('\n')
        lines = []
        #wpath  = Part.Wire(spath.Edges)
        bpoint = points[0]
        shapes = []
        shapes.append(bar)
        obj.Shape = bar
class _Rebar_L_shape(_Rebar):
        obj.ShapeCode="02"
        if self.clone(obj):
            return
        pl = obj.Placement
        dia = obj.diameter
        A = obj.A
        B = obj.B
        R = 5*dia /2.
        import Part
        points = []
        #points.append(Vector(B,0,A))
        lines = []
        bpoint = points[0]
        shapes = []
        shapes.append(bar)
        obj.Shape = bar
class _Rebar_Stirrup(_Rebar):
        obj.addProperty("App::PropertyInteger","n","Rebar","The Number  of stirrups")
        obj.addProperty("App::PropertyEnumeration","Type","Rebar","The Type of hook rebar")
        obj.addProperty("App::PropertyLength","Spacing","Rebar","The spacing between the bars")
        obj.n = 1
        obj.Spacing = 150
        obj.Type = ['1','2','3']
        if self.clone(obj):
            return
        pl = obj.Placement
        #dia = int(obj.diameter.split()[0] )
        dia = obj.diameter
        A = obj.A
        B = obj.B
        R = 4*dia /2.
        import Part
        points = []
        if obj.Type=='1':
            points.append(Vector(-A/2.,+B/2.-R-12*dia,0))
            points.append(Vector(-A/2.,+B/2.,0))
            points.append(Vector(+A/2.,+B/2.,0))
            points.append(Vector(+A/2.,-B/2.,0))
            points.append(Vector(-A/2.,-B/2.,+dia))
            points.append(Vector(-A/2.,+B/2.,+dia))
            points.append(Vector(-A/2.+R+12*dia,+B/2.,+dia))
        elif obj.Type=='2':
            #Msg('Type=2\n')
            x = -A/2.; y =+B/2.
            dy = R + R* cos(radians(45))
            x1 = x + R - R* cos(radians(45))
            y1 = y - dy
            l_hook = 6*dia*cos(radians(45))
            points.append(Vector(x1+l_hook ,y1-l_hook,0))
            points.append(Vector(x1-dy,y,0))
            #points.append(Vector(-A/2.,+B/2.,0))
            x1 = x + R + R* cos(radians(45))
            y1 = y - R + R* cos(radians(45))
            points.append(Vector(x,y1+dy,+dia))
            points.append(Vector(x1+l_hook,y1-l_hook,+dia))
        elif obj.Type=='3':
            x = -A/2.; y =-B/2.
            dx = R + R* cos(radians(45))
            dy = dx
            x1 = x + dx
            y1 = y + R - R* cos(radians(45))
            points.append(Vector(x1+l_hook,y1+l_hook,0))
            points.append(Vector(x,y1-dy,0))
            x = -A/2.; y =+B/2.
            points.append(Vector(x,y,0))
        lines = []
        bpoint = points[0]
        shapes = []
        if obj.n ==1:
            shapes.append(bar)
            #if hasattr(obj,"Spacing"):
                #obj.Spacing = 0
        else:
            #interval = size - (obj.OffsetStart.Value + obj.OffsetEnd.Value)
            #interval = interval / (obj.n - 1)
            for i in range(obj.n):
                if i==0:
                    shapes.append(bar)
                if i>0:
                    bar = bar.copy()
                    bar.translate(Vector(0,0,obj.Spacing ))
                    shapes.append(bar)
        if shapes:
            obj.Shape = Part.makeCompound(shapes)
            obj.Placement = pl
class _ViewProviderRebar(ArchComponent.ViewProviderComponent):
    def __init__(self,vobj):
        ArchComponent.ViewProviderComponent.__init__(self,vobj)
        vobj.ShapeColor = (0.67,0.00,0.00)
    def getIcon(self):
        import Arch_rc
        return ":/icons/Arch_Rebar_Tree.svg"
def makeRebarU(dia=12 , A=300 , B=1000 , placement = (0,0,0) ):
    obj = FreeCAD.ActiveDocument.addObject("Part::FeaturePython","Reinforcing Bar")
    _Rebar_U_shape(obj)
    obj.diameter = dia
    obj.A = A
    obj.B = B
    obj.Placement.Base = Vector(placement)
    if FreeCAD.GuiUp:
        _ViewProviderRebar(obj.ViewObject)
    return obj
def makeRebarL(dia=12 , A=300 , B=1000 , placement = (0,0,0) ):
    _Rebar_L_shape(obj)
    obj.diameter = dia
    obj.A = A
    obj.B = B
    if FreeCAD.GuiUp:
    return obj
def makeStirrup(dia=6 , A=150 , B=350 , Type='1' , placement = (0,0,0) ):
    obj = FreeCAD.ActiveDocument.addObject("Part::FeaturePython","Stirrup")
    _Rebar_Stirrup(obj)
    obj.diameter = dia
    obj.A = A
    obj.B = B
    obj.Type = Type
    if FreeCAD.GuiUp:
    return obj
def Test_Rebar_L():
    return makeRebarL(dia= 15  , A = 300 , B = 1000, placement = (0, 0, 0))
def Test_Rebar_U():
    return makeRebarU(dia= 15  , A = 300 , B = 1000, placement = (0, 0, 0))
if __name__=="__main__":
    #rebar1 = makeRebar2()
    #rebar2 = makeRebar2(placement = (0, 500, 0))
    #rebar3 = makeRebar2(dia= 25 , placement = (0, 1000, 0))
    #rebar4 = makeRebar2(dia= 32  , A = 500 , B = 1200, placement = (0, 1500, 0))
    spacing = 100
    for z in range(150,3000-150 , spacing):
        stirrup1 = makeStirrup(A=150, B = 150, Type='2' ,placement = (0, 0, z))
        stirrup1.ViewObject.ShapeColor=(0.67,1.00,0.50)
    main1 = makeRebarU(dia= 15  , A = 300 , B = 3800, placement = (0, 0, 0))
    pos = Vector(100 , 100-25 , 350)
    rot = FreeCAD.Rotation(FreeCAD.Vector(1,0,0),180)
    newplace = FreeCAD.Placement(pos,rot )
    main1.Placement=newplace
    main1.Label='main1'
    main2 = makeRebarU(dia= 15  , A = 300 , B = 3800, placement = (0, 0, 0))
    pos = Vector(100 , -100+25 , 350)
    main2.Placement=newplace
    main2.Label='main2'
    main3 = makeStirrup(dia= 15  , A = 200 , B = 3800-3*15, placement = (100+1.5*15 , 100-25 , 25+6+15/2))
    main3.Label='main3'
    main4 = makeStirrup(dia= 15  , A = 200 , B = 3800-3*15, placement = (100+1.5*15 , -100+25 , 25+6+15/2))
    main4.Label='main4'
    spacing = 100
    z = 350/2 + 25+6 -15
    for x in range(200+175/2, 3800-spacing , spacing):
        stirrup1 = makeStirrup(A=350-15, B = 150+15+6, Type='2' ,placement = (x, 0, z))
        stirrup1.Placement.Rotation = FreeCAD.Rotation(FreeCAD.Vector(0,1,0),90)
    dx = 100-25
    main1 = makeRebarL(dia= 15  , A = 300 , B = 3800, placement = (0, 0, 0))
    main1.Label='main1'
    pos = Vector(dx , dx , 15*3)
    rot = FreeCAD.Rotation(-135,-90,0) # Yaw-Pitch-Roll
    main2 = makeRebarL(dia= 15  , A = 300 , B = 3800, placement = (0, 0, 0))
    main2.Label='main2'
    pos = Vector(-dx , dx , 15*3)
    rot = FreeCAD.Rotation(-45,-90,0) # Yaw-Pitch-Roll
    main3 = makeRebarL(dia= 15  , A = 300 , B = 3800, placement = (0, 0, 0))
    main3.Label='main3'
    pos = Vector(-dx , -dx , 15*3)
    rot = FreeCAD.Rotation(45,-90,0) # Yaw-Pitch-Roll
    main3.Placement=newplace
    main4 = makeRebarL(dia= 15  , A = 300 , B = 3800, placement = (0, 0, 0))
    main4.Label='main4'
    pos = Vector(dx , -dx , 15*3)
    rot = FreeCAD.Rotation(135,-90,0) # Yaw-Pitch-Roll
    main4.Placement=newplace
    gap = 1
    spacing = 100
    b = 200-2*25 + 6 +15 + gap
    for z in range(150,3800-400-100 , spacing):
        stirrup1 = makeStirrup(A=b, B = b, Type='2' ,placement = (0, 0, z))
    if True:
        stirrup1 = makeStirrup(A=350, B = 150, Type='3' ,placement = (0, 0, 0))
        rot = FreeCAD.Rotation(0,90,0) # Yaw-Pitch-Roll
        stirrup1.Placement.Rotation = rot
        stirrup1.n=5
    #rebar1 = Test_Rebar_L()
    #rebar1.Placement.Base = Vector(0,1000,0)
    #rebar2 = Test_Rebar_U()
    #rebar2.Placement.Base = Vector(0,1500,0)
    FreeCAD.ActiveDocument.recompute()
    Msg("\nDone!!\n\n")
bernd
Post by bernd »
OS: Debian GNU/Linux 8.5 (jessie)
Version: 0.17.8280 (Git)
Build type: Unknown
Branch: occt7netgen
Hash: f2d12e4af256732dfc86d27702b5446bc4fef58d
Python version: 2.7.9
Qt version: 4.8.6
OCC version: 7.0.0
but I had to remove some trailing whitespaces because of intendation errors ...
   ArchRebar2.py
import Draft
        self.Type = "Rebar"
        return []
        pass
        if self.clone(obj):
            return
        dia = obj.diameter
        R = 5*dia /2.
        points = []
        lines = []
        bpoint = points[0]
        shapes = []
        shapes.append(bar)
        obj.Shape = bar
        obj.ShapeCode="00"
        if self.clone(obj):
            return
        pl = obj.Placement
        dia = obj.diameter
        A = obj.A
        B = obj.B
        R = 5*dia /2.
        #R = 0
        import Part
        points = []
            Msg(points[i])
            Msg('\n')
        lines = []
        bpoint = points[0]
        shapes = []
        shapes.append(bar)
        obj.Shape = bar
        obj.ShapeCode="02"
        if self.clone(obj):
            return
        pl = obj.Placement
        dia = obj.diameter
        A = obj.A
        B = obj.B
        R = 5*dia /2.
        import Part
        points = []
        lines = []
        bpoint = points[0]
        shapes = []
        shapes.append(bar)
        obj.Shape = bar
        obj.n = 1
        obj.Spacing = 150
        if self.clone(obj):
            return
        pl = obj.Placement
        dia = obj.diameter
        A = obj.A
        B = obj.B
        R = 4*dia /2.
        import Part
        points = []
        if obj.Type=='1':
        elif obj.Type=='2':
            #Msg('Type=2\n')
            x = -A/2.; y =+B/2.
            y1 = y - dy
        elif obj.Type=='3':
            x = -A/2.; y =-B/2.
            dy = dx
            x1 = x + dx
            x = -A/2.; y =+B/2.
        lines = []
        bpoint = points[0]
        shapes = []
        if obj.n ==1:
            shapes.append(bar)
                #obj.Spacing = 0
        else:
                if i==0:
                    shapes.append(bar)
                if i>0:
                    bar = bar.copy()
                    shapes.append(bar)
        if shapes:
            obj.Placement = pl
    def getIcon(self):
        import Arch_rc
    _Rebar_U_shape(obj)
    obj.diameter = dia
    obj.A = A
    obj.B = B
    if FreeCAD.GuiUp:
    return obj
    _Rebar_L_shape(obj)
    obj.diameter = dia
    obj.A = A
    obj.B = B
    if FreeCAD.GuiUp:
    return obj
    _Rebar_Stirrup(obj)
    obj.diameter = dia
    obj.A = A
    obj.B = B
    obj.Type = Type
    if FreeCAD.GuiUp:
    return obj
def Test_Rebar_L():
def Test_Rebar_U():
    spacing = 100
    main1.Label='main1'
    main2.Label='main2'
    main3.Label='main3'
    main4.Label='main4'
    spacing = 100
    dx = 100-25
    main1.Label='main1'
    main2.Label='main2'
    main3.Label='main3'
    main4.Label='main4'
    gap = 1
    spacing = 100
    if True:
        stirrup1.n=5
    FreeCADGui.activeDocument().activeView().viewAxonometric()
    FreeCADGui.SendMsgToActiveView("ViewFit")
    Msg("\nDone!!\n\n")
bernd
Post by bernd »
wow other diameter and width and legth works too ...
It is starting to really make fun !
BTW: @Yorik and chakkree and others
At the moment the rebar and space and count are in one object. But in a building or even in one wall or slab one type (shape) of rebar can be on different places just with other spaces and count. Means we could have two objects one defining the shape of the rebar and one defining the count and the spacing between the rebars.
cheers bernd
yorik
Founder
Post by yorik »
bernd wrote:Means we could have two objects one defining the shape of the rebar and one defining the count and the spacing between the rebars.
This is the case with arch Rebar1 already, you can build two from the same base sketch. since the Rebar2 above builds its own base wire, indeed that doesn't work. But the Rebar2 with all its derivate cases is already pretty powerful... Yes I think the code that builds the base wire should be split from the rest, this would allow the same level of freedom as the Rebar1, where you can if you want, draw yourself your own rebar...
chakkree
Post by chakkree »
Add new shape rebar for basic slab reinforcement.
   ArchRebar2.py
   22 Aug 2016
import Draft
        self.Type = "Rebar"
        return []
        pass
        if self.clone(obj):
            return
        dia = obj.diameter
        R = 5*dia /2.
        points = []
        lines = []
        bpoint = points[0]
        shapes = []
        shapes.append(bar)
        obj.Shape = bar
        obj.ShapeCode="00"
        if self.clone(obj):
            return
        pl = obj.Placement
        dia = obj.diameter
        A = obj.A
        B = obj.B
        R = 5*dia /2.
        #R = 0
        import Part
        points = []
            Msg(points[i])
            Msg('\n')
        lines = []
        bpoint = points[0]
        shapes = []
        shapes.append(bar)
        obj.Shape = bar
        obj.ShapeCode="02"
        if self.clone(obj):
            return
        pl = obj.Placement
        dia = obj.diameter
        A = obj.A
        B = obj.B
        R = 5*dia /2.
        import Part
        points = []
        lines = []
        bpoint = points[0]
        shapes = []
        shapes.append(bar)
        obj.Shape = bar
        obj.n = 1
        obj.Spacing = 150
        if self.clone(obj):
            return
        pl = obj.Placement
        dia = obj.diameter
        A = obj.A
        B = obj.B
        R = 4*dia /2.
        import Part
        points = []
        if obj.Type=='1':
        elif obj.Type=='2':
            #Msg('Type=2\n')
            x = -A/2.; y =+B/2.
            y1 = y - dy
        elif obj.Type=='3':
            x = -A/2.; y =-B/2.
            dy = dx
            x1 = x + dx
            x = -A/2.; y =+B/2.
        lines = []
        bpoint = points[0]
        shapes = []
        if obj.n ==1:
            shapes.append(bar)
                #obj.Spacing = 0
        else:
                if i==0:
                    shapes.append(bar)
                if i>0:
                    bar = bar.copy()
                    shapes.append(bar)
        if shapes:
            obj.Placement = pl
class _Rebar_shape_ACI01(_Rebar):
        obj.addProperty("App::PropertyDistance","G","Rebar","The G length of this rebar")
        obj.addProperty("App::PropertyDistance","J","Rebar","The J length of this rebar")
        obj.ShapeCode="ACI01"
        if self.clone(obj):
            return
        pl = obj.Placement
        dia = obj.diameter
        A = obj.A
        B = obj.B
        G = obj.G
        J = obj.J
        R = J/2.0
        import Part
        V1 = Vector(A,0,J)
        V2 = Vector(J/2.,0,J)
        VC1 = Vector(0,0,J/2.)
        V3 = Vector(J/2.,0,0)
        V4 = Vector(B-J/2.,0,0)
        VC2 = Vector(B,0,J/2.)
        V5 = Vector(B-J/2.,0,J)
        V6 = Vector(B-G,0,J)
        lines = []
        lines.append( Part.Line(V1,V2) )
        lines.append( Part.Arc(V2,VC1,V3) )
        lines.append( Part.Line(V3,V4) )
        lines.append( Part.Arc(V4,VC2,V5) )
        lines.append( Part.Line(V5,V6) )
        bpoint = V1
        bvec = V2.sub(V1).normalize()
        shapes = []
        if obj.n ==1:
            shapes.append(bar)
                #obj.Spacing = 0
        else:
                if i==0:
                    shapes.append(bar)
                if i>0:
                    bar = bar.copy()
                    bar.translate(Vector(0,obj.Spacing,0 ))
                    shapes.append(bar)
        if shapes:
            obj.Placement = pl
    def getIcon(self):
        import Arch_rc
    _Rebar_U_shape(obj)
    obj.diameter = dia
    obj.A = A
    obj.B = B
    if FreeCAD.GuiUp:
    return obj
    _Rebar_L_shape(obj)
    obj.diameter = dia
    obj.A = A
    obj.B = B
    if FreeCAD.GuiUp:
    return obj
    _Rebar_Stirrup(obj)
    obj.diameter = dia
    obj.A = A
    obj.B = B
    obj.Type = Type
    if FreeCAD.GuiUp:
    return obj
dia = 9
factor = 6
def makeRebar_shape_ACI01(dia=dia , A=(factor/2+4)*dia , B=1000 , G=(factor/2+4)*dia , J=factor*dia ,
      n=1 , spacing=200,  placement = (0,0,0)):
    obj = FreeCAD.ActiveDocument.addObject("Part::FeaturePython","RebarACI01")
    _Rebar_shape_ACI01(obj)
    obj.diameter = dia
    obj.A = A
    obj.B = B
    obj.G = G
    obj.J = J
    obj.n = n
    obj.Spacing = spacing
    if FreeCAD.GuiUp:
    return obj
def Test_Rebar_L():
def Test_Rebar_U():
    if False:
        rebar1 = makeRebarU()
        rebar2 = makeRebarU(placement = (0, 500, 0))
        rebar3 = makeRebarU(dia= 25 , placement = (0, 1000, 0))
        rebar4 = makeRebarU(dia= 32  , A = 500 , B = 1200, placement = (0, 1500, 0))
    spacing = 100
    main1.Label='main1'
    main2.Label='main2'
    main3.Label='main3'
    main4.Label='main4'
    spacing = 100
    dx = 100-25
    main1.Label='main1'
    main2.Label='main2'
    main3.Label='main3'
    main4.Label='main4'
    gap = 1
    spacing = 100
    if False:
        stirrup1.n=5
    if True:
        rebarACI01= makeRebar_shape_ACI01(dia=12 , A = 300 , B=4000 , G=300,J=12*6)
        rebarACI02= makeRebar_shape_ACI01(dia=12 , A = 300 , B=4000 , G=300,J=12*6)
    Msg("\nDone!!\n\n")
Test_SlabRebar01.FCStd
(28.57 KiB) Downloaded 38 times
bernd
Post by bernd »
You where defining shape codes as an Attribute! Where do you get the shape code from? Is it some standard from your country, some international standard or just your internal code?
chakkree
Post by chakkree »
Now.I'm not sure on shapecode attribute. may be ... ahhh. :oops:
yorik
Founder
Post by yorik »
yorik wrote:I think the code that builds the base wire should be split from the rest, this would allow the same level of freedom as the Rebar1, where you can if you want, draw yourself your own rebar...
I have another (better) idea: Let's make the rebar1 a sub-case of rebar2.
chakkree
Post by chakkree »
yorik wrote: I have another (better) idea: Let's make the rebar1 a sub-case of rebar2.
Maybe create a new toolbar in ArchWorkbench,"Arch Rebar tool"?
yorik
Founder
Post by yorik »
chakkree wrote:Maybe create a new toolbar in ArchWorkbench,"Arch Rebar tool"?
With drop-down items... Very good idea. I just made one like that for Arch Pipes.
