Big rewrite of extrusion-based Arch objects and IFC export
A forum dedicated to the Arch module development
yorik
Site Admin
Postby yorik » Thu Oct 27, 2016 5:25 pm
I pushed today git commit 65aaf16 which redefines a lot of things inside the Arch workbench. I did quite intense testing, but there might still be issues here and there. Symptoms would be Arch objects that are based on extrusion (walls, structures and panels) that behave differently, or that might have "jumped" out of place when opening an old file. Hopefully there won't be many. If you see something, report back and I'll try to fix ASAP.
These changes are basically to behave more like IFC wants, so the export to IFC became better. While, in FreeCAD, we don't care much if a particular object is an extrusion or not, for other apps like Revit it is crucial. So this now allows many more objects to be exported as extrusions.
The problem was that IFC wants extrusions to be done in a very specific manner: The profile must be on the XY plane, and rotated/moved into place only after it was extruded. That is the main reason for the changes below.
What has changed:
- All Arch objects now have a getExtrusionData() method, that returns a (2dprofile, extrusionVector, placement) tuple, or None if this object is not an extrusion. The 2D profile is ALWAYS in the XY plane, and centered on the origin point. The placement must be applied to both the profile and the extrusion vector, before extruding, in order to produce the final shape. By default, it returns an empty tuple, unless this object is a clone of an extruded object, or if its base object is a Part Extrusion.
- The getExtrusionData() is meant to be reimplemented by all Arch objects that perform such extrusions. So far only walls and structures have one. The execute() function makes
- The IFC exporter now uses this system, and is -as far as i tested- able to export any extruded object correctly. Additionally, this can also save quite a lot of filesize, since profiles are now stored and shared between the different extrusions.
bernd
Re: Big rewrite of extrusion-based Arch objects and IFC export
Postby bernd » Fri Oct 28, 2016 5:33 am
wow cool. Since I use export of ifc quite often and use latest master for this I will keep an eye on this.
saso
Postby saso » Fri Oct 28, 2016 3:19 pm
Sounds very promising and after a few quick tests I also did not find any issues... Again, Thank you! :)
yorik
Site Admin
Postby yorik » Fri Oct 28, 2016 5:15 pm
We now have several ways to put some "parametricism" into an IFC file:
- using clones (this uses an IfcMappedRepresentation, the IFC way to share shapes
- basing several elements on a same profile
One thing I tried to do but didn't succeed, is this: Some objects are based on extrusions, some not. For example, several Arch structures based on a Part Box. The ideal would be to export the box geometry representation once, and have the different structure objects use the same representation. Unfortunately that didn't seem to work well in my tests (the IFC object can apparently not have a different placement than its representation).
So a further step would be to detect such objects and make them IfcMappedRepresentations too.
But I'm also interested in the new serializer that IfcOpenShell has, the export is really fast! Unfortunately only IfcOpenShell seems to support the IfcAdvancedBrep object :D I can't test anywhere!
bernd
Postby bernd » Mon Oct 31, 2016 5:29 pm
Could you post an example? Allplan has a BIM cloud supporting IFC4 import already. They may support the IfcAdvancedBrep. AFAIK IfcAdvancedBrep was introduced with IFC2x4 but most CAD only support IFC2x3
paullee
Postby paullee » Thu Feb 23, 2017 7:49 pm
yorik wrote:I pushed today git commit 65aaf16 which redefines a lot of things inside the Arch workbench. I did quite intense testing, but there might still be issues here and there. Symptoms would be Arch objects that are based on extrusion (walls, structures and panels) that behave differently, or that might have "jumped" out of place when opening an old file. Hopefully there won't be many. If you see something, report back and I'll try to fix ASAP.
Hi, I am not sure if i am suffering from some bug related to this.
I have been struggling fixing the normal axis of projections (window head, cill etc.) on a facade... [In fact, I had problem of understanding the Normal Axis is global or Local in fact...]. The current problem is:-
I have many facades (supposed to be) look like this with window head, cill, other projections in Image 1.
(Image 1)
But now it look like this in Image 2 - the window head and two side projection go opposite direction.
(Image 2)
(Image 3)
In fact, the full story is longer and way back earlier -
i worked out this and other facades in FC 0.16. Default normal for all these projections (Arch Structure based on Sketch) is 0,0,0; after some while saving, re-opening, editing, some projections go in 'wrong directions' (randomly?) and I had, some of these projections in these direction Normal 'fixed' to x=-1 - the 'absolute' 'global coordinates' I thought, then they go in the 'correct' direction 'supposed to be' as shown in Image 1)
Recently, when I edit these facades in FC0.17, they go in wrong directions again. Now it seems the Normal of these projection needs to become 'Local Coordinates'.
I struggle 'fixing' all projections (many other not included in the *.fcstd below) Normal z=1 (the 'Local Coordinates'?)
[Image 4 - examples of projections highlighted with z=1]
However, whilst all other projections direction 'fixed' by setting z=1, this particular projection on this particular facade do not fix with z=1 but z=-1!?
(Note in the Image 1 'Opposed to be', in fact I had this projection Normal z set to -1 to 'falsify' this 'supposed to be' image for this post)
I have checked the underlying sketch seem have the normal on the 'correct' direction.
I have tested with Version: 0.17.9747 & Version: 0.17.10236 but no luck, same result.
p.s.
The 2 windows transparency were set to 85, but sometime it doen't work as shown in Imag3.
Any idea? Thanks!
[Image 1 - Supposed to be]
Screenshot from 2017-02-24 03-09-46.png (198.8 KiB) Viewed 137 times
[Image 2 - Now it is - - - had all projections Normal 'fixed' to z=1, used to be x=-1 to work]
Screenshot from 2017-02-24 02-26-51.png (213.04 KiB) Viewed 137 times
[Image 3 - the particular projection go in 'opposite' direction?]
Screenshot from 2017-02-24 02-52-20.png (240 KiB) Viewed 137 times
[Image 4 - some examples of projections Normal 'fixed' to z=1, used to be x=-1 to work]
Screenshot from 2017-02-24 02-27-47.png (231.35 KiB) Viewed 137 times
OS: Linux
Version: 0.17.9747 (Git)
Build type: None
Hash: f5c0f579cbd7ce668727f8835946e4e9abc0eec6
Python version: 2.7.6
Qt version: 4.8.6
OCC version: 6.8.0.oce-0.17
OS: Linux
Version: 0.17.10236 (Git)
Build type: Unknown
Hash: dd20ba3d068c4a0903417d93144f8ac7fed068e9
Python version: 2.7.13
Coin version: 3.1.3
