Test create svg grid line on TechDraw
chakkree
Post by chakkree »
   Test on TechDraw
from xml.etree import ElementTree as et
page = None
for o in FreeCAD.ActiveDocument.Objects:
	if o.isDerivedFrom('TechDraw::DrawPage'):
		page = o
		break
def VGrid(Label='A' , length = 100):
    w = 10
    h = 10
    r = 3
    gridSVG = et.Element('svg' ,width='%gmm'%w , height='%gmm'%h , viewBox='0 0 %g %g'%(w,h) )
    gridSVG.append(et.Element('circle' , cx='0' , cy='%g'%(-30-r), r='%g'%(r) , style='fill:white;stroke:black;stroke-width:0.25;'))
    gridSVG.append(et.Element('line' , x1='0' , y1='-20', x2='0' , y2='%g'%length , style='stroke:black;stroke-width:0.25;stroke-dasharray:5 2 1 2;'))
    text1 = et.Element('text' , x='0' , y='%g'%(-30-r+0.5*r) )
    text1.text = Label
    text1.set('style' , 'text-anchor:middle;font-size:4.5;' )
    gridSVG.append(text1)
    gridSVG.append(et.Element('line' , x1='-2' , y1='0', x2='2' , y2='0' , style='stroke:red;stroke-width:0.18;'))
    return gridSVG
def HGrid(Label='1' , length = 100):
    w = 10
    h = 10
    r = 3
    gridSVG.append(et.Element('circle' , cy='0' , cx='%g'%(-30), r='%g'%(r) , style='fill:white;stroke:black;stroke-width:0.25;'))
    gridSVG.append(et.Element('line' , y1='0' , x1='-20', y2='0' , x2='%g'%length , style='stroke:black;stroke-width:0.25;stroke-dasharray:5 2 1 2;'))
    text1 = et.Element('text'  , x='%g'%(-30), y='%g'%(+0.5*r) )
    text1.text = Label
    #gridSVG.append(et.Element('line' , x1='-2' , y1='0', x2='2' , y2='0' , style='stroke:red;stroke-width:0.18;'))
    return gridSVG
x_org=50; y_org = 150
scale = 1/100.
GridX = [
  {'name':'A' , 'pos':0   },
  {'name':'B' , 'pos':4000   },
  {'name':'C' , 'pos':4000   },
GridY = [
  {'name':'1' , 'pos':0   },
  {'name':'2' , 'pos':3500   },
  {'name':'3' , 'pos':3500   },
posX = x_org
for iGrid in GridX:
    name = 'Grid' + iGrid['name']
    mySymbol = FreeCAD.ActiveDocument.addObject('TechDraw::DrawViewSymbol',name)
    page.addView(mySymbol)
    posX += iGrid['pos']*scale
    mySymbol.X = posX
    mySymbol.Y = y_org
    mySymbol.setExpression('Scale', u'1 / 3.5')
    mySymbol.Symbol=et.tostring(VGrid(iGrid['name']))
posY = y_org
for iGrid in GridY:
    posY -= iGrid['pos']*scale
    mySymbol.X = x_org
    mySymbol.Y =  posY
    mySymbol.Symbol=et.tostring(HGrid(iGrid['name']))
FreeCAD.ActiveDocument.recompute()
Drawing Template
A4_Landscape_Plain.svg
(2.52 KiB) Downloaded 137 times
microelly2
Re: Test create svg grid line on TechDraw
Post by microelly2 »
Thank you for sharing this example.
chakkree
Post by chakkree »
But TechDraw has some bug when export page to svg file, size of paper has change from width="297mm" height="210mm" to width="301.752mm" height="213.36mm"
checked...
301.752/297 = 1.016 and 213.36/210 = 1.016
this ratio is same value to 25.4/25 = 1.016
may be convertional factor from mm to in have not same value.
Header of output svg file.
<?xml version="1.0" encoding="UTF-8" standalone="no"?>
<svg width="301.752mm" height="213.36mm"
 viewBox="0 0 297 210"
 xmlns="http://www.w3.org/2000/svg" xmlns:xlink="http://www.w3.org/1999/xlink"  version="1.2" baseProfile="tiny">
<title>FreeCAD SVG Export</title>
<desc>Drawing page: Page exported from FreeCAD document: Unnamed</desc>
Post by Kunda1 »
chakkree wrote:But TechDraw has some bug when export page to svg file, size of paper has change from width="297mm" height="210mm" to width="301.752mm" height="213.36mm"
checked...
Is this bug still reproducible? Andregistered on th tracker?
sgrogan
Post by sgrogan »
Kunda1 wrote: Is this bug still reproducible? Andregistered on th tracker?
See here: https://www.forum.freecadweb.org/viewto ... 35&t=21597
"fight the good fight"
chakkree
Post by chakkree »
I exported SVG for check, Now TechDraw can export with not change a size of SVG's working area.
<svg width="297mm" height="210mm"
 viewBox="0 0 2970 2100"
Version: 0.17.11054 (Git)
Hash: 36c60d3f8d924799e805ce56cb6e8fe6e49cf12b
Python version: 2.7.8
OCC version: 7.1.0
