Moving window with wall
cnirbhay
Post by cnirbhay »
Version: 0.17.9528 (Git)
Hash: 4efd3e894a9d3c1954603c60c411d434506d44e7
Python version: 2.7.8
OCC version: 7.0.0
When we place a window on a wall, and then displace the wall by a distance in a particular direction, why doesn't the window move along with the wall. I believe, in general practice, the window should fix its position with the wall automatically. Revit follows this approach.
[img]
Screenshot (164).png (106.79 KiB) Viewed 5742 times
[/img]
[img]
Screenshot (165).png (115.36 KiB) Viewed 5742 times
[/img]
yorik
Founder
Re: Moving window with wall
Post by yorik »
We're still experimenting with this... There are pros and cons... But Arch objects have a "Move with host" property that you can set to True. Then, the window will move with the wall.
cnirbhay
Post by cnirbhay »
yorik wrote:We're still experimenting with this... There are pros and cons... But Arch objects have a "Move with host" property that you can set to True. Then, the window will move with the wall.
No, Sir, it didn't move. I tried this. :-(
yorik
Founder
Post by yorik »
Then it is a bug :) I'll look into it.
yorik
Founder
Post by yorik »
Ok, I see... the window will only move together when using the draft move tool. When changing the placement manually, the window doesn't move. I'll try to think of a way to solve this
paullee
Post by paullee »
yorik wrote: Sat Jan 21, 2017 8:33 pm Ok, I see... the window will only move together when using the draft move tool. When changing the placement manually, the window doesn't move. I'll try to think of a way to solve this
Hi, not move together with draft move tool - anything missing?
OS: Linux
Version: 0.17.12479 (Git)
Build type: None
Hash: 09fe85e8ff6de19d5261701dd21d9a0cd9d74af8
Python version: 2.7.6
Qt version: 4.8.6
OCC version: 7.1.0
Window w/ Move with Host = True
Screenshot from 2017-10-29 08-47-49.png (239.31 KiB) Viewed 5013 times
Draft move the wall (host)
Screenshot from 2017-10-29 08-48-02.png (176.08 KiB) Viewed 5013 times
Screenshot from 2017-10-29 08-48-14.png (227.5 KiB) Viewed 5013 times
Screenshot from 2017-10-29 08-48-19.png (187.75 KiB) Viewed 5013 times
The wall moved, window stayed (host)
Screenshot from 2017-10-29 08-48-35.png (238.52 KiB) Viewed 5013 times
paullee
Post by paullee »
Hi, some other issues to report - when i try to move back the windows to the wall:-
(problems a little bit confusing to myself so the following may not be articulating the problem correctly)
  • When try to move the window, it is intuitive to move the window object, but in this way the underlying sketch stayed - have problem to move the hole in this way?
(Yes, i remember when I tried to create a window on a curve wall, we have discussion how to move the underlying sketch setting normal etc... ..., but it is intuitive to move the window object itself :) )
  • (The window on the right) Seem need to move back the underlying window sketch with nearest snap onto the wall (+ host in window selected to that wall), then it create an opening - that's fine
  • The window on the left have 2 objects in its host setting when it is originally created with the window tool - whatever i draft move sketch/window, it seem it does not create an opening (after it displace when the original wall had move)
  • Now, it try to edit the host setting - can not directly edit the texts.... Can select in the dialog box the original host again...then it create an opening!
  • It seem now we have options to have the window in the wall as subtraction OR have windows' host set to a host (the latter I understand is to avoid cyclic dependency problem) - is the latter recommended / reported to be better?
Screenshot from 2017-10-29 08-48-35.png (238.52 KiB) Viewed 5011 times
Screenshot from 2017-10-29 08-57-58.png (242.96 KiB) Viewed 5011 times
Screenshot from 2017-10-29 09-00-15.png (238.79 KiB) Viewed 5011 times
Screenshot from 2017-10-29 09-02-48.png (245.62 KiB) Viewed 5011 times
2 objects in host setting changed back to 1 host
Screenshot from 2017-10-29 09-13-31.png (239.33 KiB) Viewed 5011 times
tomi_wunder
Post by tomi_wunder »
even though this is a pretty old post, this bug/problem seems to persist up to now. I'm using
OS: Debian GNU/Linux 9 (stretch)
Version: 0.18.16131 (Git) AppImage
Branch: (HEAD detached at 0.18.3)
Hash: 3129ae4296e40ed20e7b3d460b86e6969acbe1c3
Python version: 3.6.7
Qt version: 5.6.2
Locale: C/Default (C)
ex01.FCStd
(92.57 KiB) Downloaded 53 times
and I'm trying to come to grips with the arch workbench. I've created an exterior wall ("WandAussenE0") from a sketch ("GrundrissAussen") and added some windows to it. When I change the dimensions of the sketch ( e.g. "BreiteVorn" from 12m to 10m) the windows will stay in free space and don't move along with the walls as I would expect it.
Am I missing something?
Have I attached the windows incorrectly?
Thanks in advance!
vocx
Post by vocx »
tomi_wunder wrote: Mon Nov 11, 2019 12:38 am ... When I change the dimensions of the sketch ( e.g. "BreiteVorn" from 12m to 10m) the windows will stay in free space and don't move along with the walls as I would expect it....
The windows don't have a notion of the shape of the wall. When you place them, you just place them in the space where the wall has its face, but there is nothing linking the window and the wall. The window doesn't track the shape of the wall to auto-adjust its position; you have to re-position the windows manually.
See this, Tutorial custom placing of windows and doors.
tomi_wunder
So, if I got you right, window objects only observe their "host's" placement attribute (iff moveWithHost is enabled).
Is there any workaround how I can fix them to a parametric geometry anyways?
(It would be a really nice feature to place windows or doors based on a Sketch (in the floor plane) that just references a groundplan's (also a Sketch's "GrundrissAussen") geometry and so adapts the geometry changes of that groundplan.)
