Hi, i notice the idea of Xref or the like is being considered in FC.
I used to work in autocad for a long while and Xref function really help in combining / cloning copies without expanding the file size a lot.
I have been modelling whilst learning FC as a test a multi-storey building. I am testing the Arch Building and are successful in creating Options of buildings based on a combination of main building with different parts. This is really handy!
I try to clone the Building Object, 1 copy only as a test, to see if an estate of towers could be produced.
Some issues found:-
- File become >22MB, for 1 clone, from about 15MB!
- The clone does not 'inherit' properties of each components in the original model, e.g. transparency in window glass now become opaque as the clone property set
- The system become quite slow
- I haven't tried array on Building Object yet (array of a FC group does not work)
Any alternative currently anybody may think of?
Thanks.
(I have FC0.16 and different git of FC0.17_pre in win7, przemof Fedora latest build, or AppImage to run on Fedora)
(I am using git 9747 AppImage on Fedora as I face other issues discussed in Help separately)
OS: Linux
Version: 0.17.9747 (Git)
Build type: None
Hash: f5c0f579cbd7ce668727f8835946e4e9abc0eec6
Python version: 2.7.6
Qt version: 4.8.6
OCC version: 6.8.0.oce-0.17
1 Clone on the right
Clone on the right have window glass pane opaque rather than transparent i.e. same property as the Clone object
Xref / Clone / Copies of Building Object
Re: Xref / Clone / Copies of Building Object
In 0.17 the Draft clone will respect the colors and transparencies of its base shape.
However, currently that won't work when making one clone of multiple objects. I'll have a look into it, if the Part Compound does it, it should be possible here too...
A workaround for now is to create a Part Compound of all the objects, and then make a clone of that compound instead.
In blender cloning multiple objects is done using groups, maybe it can be solution here.
Thanks, not quite successful. I think I had tried Part Compound earlier for something else but maybe all we have are Arch Objects that Part Compound do not resolve to each of it components?yorik wrote:In 0.17 the Draft clone will respect the colors and transparencies of its base shape.
p.s.
I am using 0.17_pre git 9747 (AppImage running on Fedora)
OS: Linux
Build type: None
Qt version: 4.8.6
Thanks! I am still learning blender also and would like try that method. However, I would like to implement that in FC as I am trying to do some site planning study and see if any parametric modelling could be done.Eneen wrote:In blender cloning multiple objects is done using groups, maybe it can be solution here.
cheers
Starting from git commit cf7bc5bdf, Draft clones, when created, will now take color/transparencies of their cloned objects, even when the clone clones more than one. If you change the color or transparency of the clone manually after that, the original colors will be lost. However there is also a python function available to reset these colors anytime:
myClone.ViewObject.Proxy.resetColors(myClone.ViewObject)
yorik wrote:Starting from git commit cf7bc5bdf, Draft clones, when created, will now take color/transparencies of their cloned objects, even when the clone clones more than one. If you change the color or transparency of the clone manually after that, the original colors will be lost. However there is also a python function available to reset these colors anytime:
Thanks! Will definitely try soon when I return to my desktop!
