Suggested Arch Tools
been reading everywhere, but can't find a concise area where to post tools that are desired for better architectural work. So any new tool or modification of existing tools can be suggested here.
Re: Suggested Arch Tools
I think Open discussion is a more appropriate place.regis wrote:been reading everywhere, but can't find a concise area where to post tools that are desired for better architectural work. So any new tool or modification of existing tools can be suggested here.
It's directly accessible from Users Sub-forum.
or, if it's only for the Arch module, you can start a new thread in the Arch section.
regis wrote:... area where to post tools that are desired for better architectural work.
For me, Arch module's improvement need, first, Draft module's improvement (drawing aid).yorik wrote:or, if it's only for the Arch module, you can start a new thread in the Arch section.
It's why I think a wider audience is necessary.
But we can begin here if you want. What have you in mind ?
At the moment the current tools are already great, but some need a bit more refinement and consistency in the controlsjidoeuf wrote:regis wrote:... area where to post tools that are desired for better architectural work.For me, Arch module's improvement need, first, Draft module's improvement (drawing aid).yorik wrote:or, if it's only for the Arch module, you can start a new thread in the Arch section.
for example:
In this instance there is a bit of redundancy in the tools
or conflict in the tools
- Screenshot from 2017-04-21 13-37-55.png (427.21 KiB) Viewed 2070 times
- Screenshot from 2017-04-21 13-38-16.png (427.83 KiB) Viewed 2070 times
- Screenshot from 2017-04-21 13-38-52.png (713.66 KiB) Viewed 2070 times
- Screenshot from 2017-04-21 13-39-08.png (712.24 KiB) Viewed 2070 times
What the flip command does is invert the normal direction of the dimension. What the "flip text" property does is to rotate the text 180° around that normal. I think with these two features you are able to have the text in all possible situations you might want. But I agree the concept is a bit confusing, I'll make the doc a bit clearer.
yorik wrote:What the flip command does is invert the normal direction of the dimension. What the "flip text" property does is to rotate the text 180° around that normal. I think with these two features you are able to have the text in all possible situations you might want. But I agree the concept is a bit confusing, I'll make the doc a bit clearer.
I see, probably add that tool to the view tab, so it's not hidden so far away in the utilities when it has a direct use.
ability to draw and create walls and structure from vertical sketches
Currently walls can't be generated if sketch is vertical.
In the example picture for the structure, that's just a normal shape extrusion.
- wall & structure.jpg (831.42 KiB) Viewed 1779 times
