Help with DXF and arch panel tools
bitacovir
Post by bitacovir »
Working with arch panel tools for a project I imported a DXF file to create the panels in FreeCAD. The DXF drawings were only straight lines, so there was not problem. But one drawing has curves and I could not create panels. I tried to replace the curves with arcs (from FreeCAD) l but still I could not create a panel at the end. Maybe someone knows a good method to do it... I share the DXF file.
Version: 0.17.10894 (Git)
Hash: 6e5bba3999b49098cac93482a13afca243a89d04
Python version: 2.7.8
OCC version: 7.1.0
bellmouth.dxf
(219.78 KiB) Downloaded 61 times
::bitacovir::
Canal Youtube Grupo Telegram de FreeCAD Español
My personal web site
My GitHub repository
Mini Airflow Tunnel Project
yorik
Founder
Re: Help with DXF and arch panel tools
Post by yorik »
You need to select all the edges of each shape, then use Draft Upgrade twice to turn them into faces. Then you can make panels from them. It is not necessary to make faces, panels can also be made simply from closed wires, but using faces is an additional check, so youare sure these wires can become faces.
In this case, one of the shapes had duplicated lines, which prevented the wire from becoming a face. So I had to do a small manual fix.
Screenshot from 2017-04-23 18-17-55.png (87.35 KiB) Viewed 1545 times
panels.fcstd
(25.88 KiB) Downloaded 49 times
bitacovir
Post by bitacovir »
Thanks Yorik, but it is not how it works in my case. I am going to describe each step:
1) Menu File > Open > Select bellmouth.dxf file
2) The file opened shows in the Combo View a list of Polyline00x and Arc, Arc001, etc.
3) I select all the polylines and two Arcs of the left shape > Draft Upgrade > nothing happen.
4) I select all the polylines of the left shape > Draft Downgrade > polylines turn into edges in the Combo View.
5) I select all the now edges of the left shape> Draft Upgrade > nothing happen. no face, no wire.
Here the report:
not a freecad file: .DXF
opening C:/Users/Rafael/Downloads/bellmouth.dxf...
drawing 20 polylines...
drawing 4 arcs...
skipping texts...
skipping dimensions...
skipping points...
skipping leaders...
skipping hatches...
skipping *blocks...
done processing
recompute done
successfully imported C:/Users/Rafael/Downloads/bellmouth.dxf
Arch workbench activated
Unable to upgrade these objects.
Found only wires: extracting their edges
Version: 0.17.10909 (Git)
Hash: eb5c56b50297a03b275846c7bb064ad4aae094da
OCC version: 7.1.0
::bitacovir::
yorik
Founder
Post by yorik »
I did exactly the same thing as you... My guess is that in the lines/arcs you selected, there is something wrong that prevents closing a wire.
Try selecting only some of them, see if they upgrade to a wire
regis
Post by regis »
If they are not alot of stuff to upgrade, you can just redraw new draft-wires with closed poly lines. Alot simple and clean.
