I just can't figure out how you make the 'extrusion', no same data / properties field in my created facebinder in my file.... I am checking part extrude, thickness etc.
I am figuring out if I can achieve making cladding / surface for external wall, whilst another surface / shell for interior, so that I can develop a model for rendering in e.g. Blender. I found Blender had some nice tools either.
So, Q1 is how to add the extrusion.
Q2 is I note your facebinder is like padding 2 individual faces, so that there is a 'birdmouth' joint at the corner edge - which is good for some case in fact.
I am testing if 'thickness' tool can help - I have some 'projection' on my facade and it seem it help to create 'cladding' like surface offsetting from that solid.
yorik wrote:Like this:
The extrusion of the facebinder is not perfect (one sees the "sides" of the extruded faces), not sure if I can make that better...
About your problem, there is no ready solution for that yet (We definitely need something to "slice" solids to add new edges), but what I would do is
1) create a volume that intersects your wall exactly where you wan to split that face
2) subtract that volume from the wall
3) from the same volume and wall, create an intersection
4) turn the intersection into a wall as well
