IFC import
Re: IFC import
Post by bernd »
tom wrote:I don't know what the purpose of the attribute INCLUDE_CURVES is. Thus, my temporary patch may not be the proper solution for the problem. I wonder why nobody else was faced to the same issue, since the ifcOpenShell I used came from the official site. Or is this issue OS X related?
You downloaded from here:
https://sourceforge.net/projects/ifcope ... -preview1/ These previews are from February 2015! They are really outdated. It is recommended to compile an up to date version. Check https://github.com/IfcOpenShell/IfcOpenShell
BTW: This option is needed to import analytical IFC. This option was added far after these previews above where provided.
Re: IFC import
Post by yorik »
I think I saw they were in the process of creating new builds of ifcopenshell... Maybe have a look at their forums too if there isn't anything more recent
tom
Re: IFC import
Post by tom »
Hmm, I gave up compiling the IfcOpenShell on an OS X machine after 3 hours. It seems to me that I have to live without a IFC import for a while.
Re: IFC import
Post by bernd »
double post
Re: IFC import
Post by bernd »
tom wrote:Hmm, I gave up compiling the IfcOpenShell on an OS X machine after 3 hours. It seems to me that I have to live without a IFC import for a while.
fill in an issue on ifcopenshells github or on ifcopenshells forum. Thomas or Ari will for sure help you. They did help myself many times to get ifcopenshell compiled.
BTW:
there is a build sctipt which fetches and compiles all depecies.
would be cool if you get it compiled. We coulf include the binary in the osx FreeCAD release then.
tom
Re: IFC import
Post by tom »
Thank you for the hint with the build script. Will try it this evening.
pablogil
Re: IFC import
Post by pablogil »
tom wrote:Thank you for the hint with the build script. Will try it this evening.
Hi @tom,
Were you able to successfully compile ifcOpenShell for OSX? I wasn't able and I would be interested on the binaries in case you have them...
Thanks
