Inventing wheels.. with built-in suspension =p
DeepSOIC
Re: Inventing wheels.. with built-in suspension =p
Post by DeepSOIC »
Printed. Did a similar quick break test, and the wheel is OK so far...
The next planned disappointment will happen at the very end of august, when I return to the city to find out the wheel doesn't fit the kick scooter (I have not measured it :oops: )
triplus
Post by triplus »
DeepSOIC wrote:Printed.
Images or it didn't happen.
DeepSOIC
Post by DeepSOIC »
:lol:
Will post. But only if I find an interesting way to present it, since it looks exactly as the previous one, except it's not broken :P
DeepSOIC
Post by DeepSOIC »
jmaustpc wrote:It must be very difficult to design it such that you have strength, axial rigidity, rotational rigidity and yet still somehow get radial flexibility.
Axial rigidity is very good. Strength... well... trying :) . Rotational rigidity: not at all.
But I wonder, is it actually important to have rotational rigidity? For kick scooter, definitely I don't care. But for something motorized, like a car, it may be. But is it? I can imagine, rotational springiness it may seriously reduce braking performance... by a factor of two, probably.
DeepSOIC
Post by DeepSOIC »
I returned to the city, and the first thing I did was installing the wheel onto the kick scooter. It fits :shock: :o :D , I guessed the thickness!!
But the wheel turned out to be way small in diameter.
Looking at the original wheel, a stupid idea was born. Cut away the middle, and print a suspension insert!
And of course, I will try riding on that small wheel!
triplus
Post by triplus »
Well to me it looks like you came home and put what looks like a bag of groceries on the floor and went straight to installing the wheel on the kick scooter. I like that approach!
As for testing it out it does look like you will have fun over the weekend.
DeepSOIC
Post by DeepSOIC »
Test results. EPIC FAIL. :cry:
The suspension disintegrated after just 2 meters of asphalt.
But on floor, it was holding up...
yorik
Founder
Post by yorik »
The flakes flying away while you were driving the curb at high speed must have been quite a sight!
DeepSOIC
Post by DeepSOIC »
yorik wrote:The flakes flying away while you were driving the curb at high speed must have been quite a sight!
Indeed. I feel so stupid not having set up video recording of the moment.
triplus
Post by triplus »
Likely material used isn't most suitable for such task.
