NiCr: CNC Hot Wire Cutter
JMG
Post by JMG »
Hi!
I'm happy to announce that I'm publishing my CNC Hot Wire Foam Cutter (or simply NiCr, way shorter name) as an OpenSource/Hardware project.
A little video about it:
https://www.youtube.com/watch?v=iOVO2aQ5I9E
It has been designed with FreeCAD and also uses it to create the toolpath from 3D shapes.
Some pictures of the machine inside FreeCAD:
It has several interesting features like coreXY motion, arduino&ramps electronics and more, I have published a more detailed description here:
http://linuxforanengineer.blogspot.com. ... /nicr.html
I hope to upload code and 3D parts soon (FreeCAD workbench is almost ready :) )
EDITED: Github repo: https://github.com/JMG1/NiCr
Edited 2: Workbench demo video https://www.youtube.com/watch?v=8snH_p_ ... e=youtu.be
Javier.
FreeCAD scripts, animations, experiments and more: http://linuxforanengineer.blogspot.com.es/
Open source CNC hot wire cutter project (NiCr): https://github.com/JMG1/NiCr
Exploded Assembly Workbench: https://github.com/JMG1/ExplodedAssembly
triplus
Re: NiCr: CNC Hot Wire Cutter
Post by triplus »
Impressive.
DeepSOIC
Post by DeepSOIC »
Oh yes it is. Impressive. Should I start building one, I wonder...
kwahoo
Post by kwahoo »
Whoa! This thing is huge!
If I understood well, an G-Code like code is generated in FreeCAD and interpreted by AVR? Can you share some info about buffering commands? Are you sending commands in packets, or full code before staring the cutter?
JMG
Post by JMG »
DeepSOIC:
The question is... how can you live without one? :lol:
kwahoo:
Yes, you understood correctly. The nicr code is generated inside FreeCAD and sent by serial to the machine, at least, that is how it works at the moment. You can see an example on my test machine here (code included):
https://www.youtube.com/watch?v=VHL-ju65lEk
The only thing that keeps it from working perfectly are the delays between instructions, but seems easy to solve.
Also, one thing that is high in my to-do list is to create the possibility of reading the code from a SD card, like 3D printers do.
Any help and ideas with this will be greatly appreciated :)
kwahoo
Post by kwahoo »
JMG wrote: The only thing that keeps it from working perfectly are the delays between instructions, but seems easy to solve.
I started thinking about converting G-code on PC and streaming discrete steps to AVR with some buffering. I haven't tested this method yet, but I will when I'll finish my micro-CNC prototype.
JMG
Post by JMG »
In this video I'm sending the steps and direction directly (but without buffering) from a script that reads shape topology and transforms it to machine steps.
https://www.youtube.com/watch?v=InJrinMZe4A
The data sent is a binary number with direction and step. I've also used this script modified to address directly the parallel port, eliminating the need of an AVR at the expense of using an old motherboard with parallel port.
I'm sure there are a lot of ways of doing the same thing, my preference is to send human-friendly instructions because there are easier to debug (separates nicely the software inside the computer and the firmware in the AVR).
Nice project, those sliders are of the kind used in furnitures (like retractable keyboard trays)?
Javier.
JMG
Post by JMG »
Hi all.
The NiCr repository is here!! :D
The workbench Includes a .fcstd file with an example.
Javier.
triplus
Post by triplus »
Looking good. I do get this:
  File "...NiCr_Workbench/NiCrSimMachine.py", line 53, in onChanged
    self.addMachineToDocument( fp.FrameDiameter, fp.XLength, fp.YLength, fp.ZLength )
<type 'exceptions.AttributeError'>: 'FeaturePython' object has no attribute 'YLength'
<type 'exceptions.AttributeError'>: 'FeaturePython' object has no attribute 'ZLength'
When loading the provided example .fcstd file.
JMG
Post by JMG »
Thanks triplus for testing! :)
That annoying error shows when loading a workbench within a saved document, I think that is related to the save/load mechanism of the python objects :? It is not critical and does not disturb the workbench behavior.
