NiCr: CNC Hot Wire Cutter
microelly2
Re: NiCr: CNC Hot Wire Cutter
Post by microelly2 »
You have to install an extra python modul pyserial
https://github.com/pyserial/pyserial
vcode
Post by vcode »
Thanks microelly2,
I installed pyserial module, but nothing changed. i got the same problem.
There is the installation...
D:\vslot\pyserial-master>python setup.py install
running install
running bdist_egg
running egg_info
creating pyserial.egg-info
writing top-level names to pyserial.egg-info\top_level.txt
writing dependency_links to pyserial.egg-info\dependency_links.txt
writing pyserial.egg-info\PKG-INFO
writing manifest file 'pyserial.egg-info\SOURCES.txt'
reading manifest file 'pyserial.egg-info\SOURCES.txt'
reading manifest template 'MANIFEST.in'
installing library code to build\bdist.win32\egg
running install_lib
running build_py
creating build
creating build\lib
creating build\lib\serial
copying serial\aio.py -> build\lib\serial
copying serial\rfc2217.py -> build\lib\serial
copying serial\rs485.py -> build\lib\serial
copying serial\serialcli.py -> build\lib\serial
copying serial\serialjava.py -> build\lib\serial
copying serial\serialposix.py -> build\lib\serial
copying serial\serialutil.py -> build\lib\serial
copying serial\serialwin32.py -> build\lib\serial
copying serial\win32.py -> build\lib\serial
copying serial\__init__.py -> build\lib\serial
creating build\lib\serial\tools
copying serial\tools\hexlify_codec.py -> build\lib\serial\tools
copying serial\tools\list_ports.py -> build\lib\serial\tools
copying serial\tools\list_ports_common.py -> build\lib\serial\tools
copying serial\tools\list_ports_linux.py -> build\lib\serial\tools
copying serial\tools\list_ports_osx.py -> build\lib\serial\tools
copying serial\tools\list_ports_posix.py -> build\lib\serial\tools
copying serial\tools\list_ports_windows.py -> build\lib\serial\tools
copying serial\tools\miniterm.py -> build\lib\serial\tools
copying serial\tools\__init__.py -> build\lib\serial\tools
creating build\lib\serial\urlhandler
copying serial\urlhandler\protocol_alt.py -> build\lib\serial\urlhandler
copying serial\urlhandler\protocol_hwgrep.py -> build\lib\serial\urlhandler
copying serial\urlhandler\protocol_loop.py -> build\lib\serial\urlhandler
copying serial\urlhandler\protocol_rfc2217.py -> build\lib\serial\urlhandler
copying serial\urlhandler\protocol_socket.py -> build\lib\serial\urlhandler
copying serial\urlhandler\protocol_spy.py -> build\lib\serial\urlhandler
copying serial\urlhandler\__init__.py -> build\lib\serial\urlhandler
creating build\lib\serial\threaded
copying serial\threaded\__init__.py -> build\lib\serial\threaded
creating build\bdist.win32
creating build\bdist.win32\egg
creating build\bdist.win32\egg\serial
copying build\lib\serial\aio.py -> build\bdist.win32\egg\serial
copying build\lib\serial\rfc2217.py -> build\bdist.win32\egg\serial
copying build\lib\serial\rs485.py -> build\bdist.win32\egg\serial
copying build\lib\serial\serialcli.py -> build\bdist.win32\egg\serial
copying build\lib\serial\serialjava.py -> build\bdist.win32\egg\serial
copying build\lib\serial\serialposix.py -> build\bdist.win32\egg\serial
copying build\lib\serial\serialutil.py -> build\bdist.win32\egg\serial
copying build\lib\serial\serialwin32.py -> build\bdist.win32\egg\serial
creating build\bdist.win32\egg\serial\threaded
copying build\lib\serial\threaded\__init__.py -> build\bdist.win32\egg\serial\threaded
creating build\bdist.win32\egg\serial\tools
copying build\lib\serial\tools\hexlify_codec.py -> build\bdist.win32\egg\serial\tools
copying build\lib\serial\tools\list_ports.py -> build\bdist.win32\egg\serial\tools
copying build\lib\serial\tools\list_ports_common.py -> build\bdist.win32\egg\serial\tools
copying build\lib\serial\tools\list_ports_linux.py -> build\bdist.win32\egg\serial\tools
copying build\lib\serial\tools\list_ports_osx.py -> build\bdist.win32\egg\serial\tools
copying build\lib\serial\tools\list_ports_posix.py -> build\bdist.win32\egg\serial\tools
copying build\lib\serial\tools\list_ports_windows.py -> build\bdist.win32\egg\serial\tools
copying build\lib\serial\tools\miniterm.py -> build\bdist.win32\egg\serial\tools
copying build\lib\serial\tools\__init__.py -> build\bdist.win32\egg\serial\tools
creating build\bdist.win32\egg\serial\urlhandler
copying build\lib\serial\urlhandler\protocol_alt.py -> build\bdist.win32\egg\serial\urlhandler
copying build\lib\serial\urlhandler\protocol_hwgrep.py -> build\bdist.win32\egg\serial\urlhandler
copying build\lib\serial\urlhandler\protocol_loop.py -> build\bdist.win32\egg\serial\urlhandler
copying build\lib\serial\urlhandler\protocol_rfc2217.py -> build\bdist.win32\egg\serial\urlhandler
copying build\lib\serial\urlhandler\protocol_socket.py -> build\bdist.win32\egg\serial\urlhandler
copying build\lib\serial\urlhandler\protocol_spy.py -> build\bdist.win32\egg\serial\urlhandler
copying build\lib\serial\urlhandler\__init__.py -> build\bdist.win32\egg\serial\urlhandler
copying build\lib\serial\win32.py -> build\bdist.win32\egg\serial
copying build\lib\serial\__init__.py -> build\bdist.win32\egg\serial
byte-compiling build\bdist.win32\egg\serial\aio.py to aio.cpython-35.pyc
byte-compiling build\bdist.win32\egg\serial\rfc2217.py to rfc2217.cpython-35.pyc
byte-compiling build\bdist.win32\egg\serial\rs485.py to rs485.cpython-35.pyc
byte-compiling build\bdist.win32\egg\serial\serialcli.py to serialcli.cpython-35.pyc
byte-compiling build\bdist.win32\egg\serial\serialjava.py to serialjava.cpython-35.pyc
byte-compiling build\bdist.win32\egg\serial\serialposix.py to serialposix.cpython-35.pyc
byte-compiling build\bdist.win32\egg\serial\serialutil.py to serialutil.cpython-35.pyc
byte-compiling build\bdist.win32\egg\serial\serialwin32.py to serialwin32.cpython-35.pyc
byte-compiling build\bdist.win32\egg\serial\threaded\__init__.py to __init__.cpython-35.pyc
byte-compiling build\bdist.win32\egg\serial\tools\hexlify_codec.py to hexlify_codec.cpython-35.pyc
byte-compiling build\bdist.win32\egg\serial\tools\list_ports.py to list_ports.cpython-35.pyc
byte-compiling build\bdist.win32\egg\serial\tools\list_ports_common.py to list_ports_common.cpython-35.pyc
byte-compiling build\bdist.win32\egg\serial\tools\list_ports_linux.py to list_ports_linux.cpython-35.pyc
byte-compiling build\bdist.win32\egg\serial\tools\list_ports_osx.py to list_ports_osx.cpython-35.pyc
byte-compiling build\bdist.win32\egg\serial\tools\list_ports_posix.py to list_ports_posix.cpython-35.pyc
byte-compiling build\bdist.win32\egg\serial\tools\list_ports_windows.py to list_ports_windows.cpython-35.pyc
byte-compiling build\bdist.win32\egg\serial\tools\miniterm.py to miniterm.cpython-35.pyc
byte-compiling build\bdist.win32\egg\serial\tools\__init__.py to __init__.cpython-35.pyc
byte-compiling build\bdist.win32\egg\serial\urlhandler\protocol_alt.py to protocol_alt.cpython-35.pyc
byte-compiling build\bdist.win32\egg\serial\urlhandler\protocol_hwgrep.py to protocol_hwgrep.cpython-35.pyc
byte-compiling build\bdist.win32\egg\serial\urlhandler\protocol_loop.py to protocol_loop.cpython-35.pyc
byte-compiling build\bdist.win32\egg\serial\urlhandler\protocol_rfc2217.py to protocol_rfc2217.cpython-35.pyc
byte-compiling build\bdist.win32\egg\serial\urlhandler\protocol_socket.py to protocol_socket.cpython-35.pyc
byte-compiling build\bdist.win32\egg\serial\urlhandler\protocol_spy.py to protocol_spy.cpython-35.pyc
byte-compiling build\bdist.win32\egg\serial\urlhandler\__init__.py to __init__.cpython-35.pyc
byte-compiling build\bdist.win32\egg\serial\win32.py to win32.cpython-35.pyc
byte-compiling build\bdist.win32\egg\serial\__init__.py to __init__.cpython-35.pyc
creating build\bdist.win32\egg\EGG-INFO
installing scripts to build\bdist.win32\egg\EGG-INFO\scripts
running install_scripts
running build_scripts
creating build\scripts-3.5
copying and adjusting serial\tools\miniterm.py -> build\scripts-3.5
creating build\bdist.win32\egg\EGG-INFO\scripts
copying build\scripts-3.5\miniterm.py -> build\bdist.win32\egg\EGG-INFO\scripts
copying pyserial.egg-info\PKG-INFO -> build\bdist.win32\egg\EGG-INFO
copying pyserial.egg-info\SOURCES.txt -> build\bdist.win32\egg\EGG-INFO
copying pyserial.egg-info\dependency_links.txt -> build\bdist.win32\egg\EGG-INFO
copying pyserial.egg-info\top_level.txt -> build\bdist.win32\egg\EGG-INFO
zip_safe flag not set; analyzing archive contents...
creating dist
creating 'dist\pyserial-3.1a0-py3.5.egg' and adding 'build\bdist.win32\egg' to it
removing 'build\bdist.win32\egg' (and everything under it)
Processing pyserial-3.1a0-py3.5.egg
Copying pyserial-3.1a0-py3.5.egg to c:\program files (x86)\python35-32\lib\site-packages
Removing pyserial 3.0.1 from easy-install.pth file
Adding pyserial 3.1a0 to easy-install.pth file
Installing miniterm.py script to C:\Program Files (x86)\Python35-32\Scripts
Installed c:\program files (x86)\python35-32\lib\site-packages\pyserial-3.1a0-py3.5.egg
Processing dependencies for pyserial==3.1a0
Finished processing dependencies for pyserial==3.1a0
And Freecad gives me the same error when trying to import NiCrSerial
File "C:\Program Files\FreeCAD 0.15\Mod\Workbench\NiCrSerial.py", line 1, in <module>
import serial
ImportError: No module named serial
Any idea?
microelly2
FreeCAD uses it own python installation
serial is installed but not found
If you type in the python console window
import serial
an error will occur.
your package is installed to
there is a pyserial-3.1a0-py3.5.egg and a serial-subdirectory
but it should be installed
your FreeCAD directory\bin\Lib\site-packages
May be it helps to copy the directory and the egg file to this position.
vcode
Post by vcode »
I've copied the files in the Freecad directory but the console says the same.
i thought it would be more easy.
I don't have any arduino board connected to my computer, it doesn't matter, really?
microelly2
It's still an installation problem, a not connected usb raises another error.
I need some time and access to a windows computer.
then I can say more.
sgrogan
Post by sgrogan »
Copying just the serial folder to .../bin/Lib/site-packages, worked for me.
"fight the good fight"
vcode
Post by vcode »
Hi sgrogan, that was the point!!
I've copied the files in the Freecad/lib/ directory and the corrent one is Freecad/bin/lib :lol:
Now works the serial lib but the SimMachine doesn't appears. :cry:
JMG
Post by JMG »
Hi vcode!
Could you give the steps needed to reproduce that issue?
Javier.
FreeCAD scripts, animations, experiments and more: http://linuxforanengineer.blogspot.com.es/
Open source CNC hot wire cutter project (NiCr): https://github.com/JMG1/NiCr
Exploded Assembly Workbench: https://github.com/JMG1/ExplodedAssembly
vcode
Post by vcode »
As you can see, in your video (left side) when you push the "Create machine" button, appears SimMachine, but in may case (right side) nothing appears.
i've tried "dev" and "master" branch with the same result.
And when i try to create a WirePath of a cube, this is what happends
JMG
Post by JMG »
Interesting....
The report view displays something when that (SimMachine not created) happens?
The third picture (box path) is not problematic, that weird path has something to do with reversed edges and only affects visualization.
edit: Have you tried the "example.fcstd" file provided?
