I made this case. Is work in progress (need some tweek in dimensions and add some screw holes).
If I make a hole in a part, I cannot move anymore
Transistor Tester Case
Re: Transistor Tester Case
Hi Rodrigo, can you provide more detail?RodrigoP wrote:If I make a hole in a part, I cannot move anymore
If you make a a sketch in a face of a solid, for example. a cube, and make a hole using the sketch in a face of the cube, the cube with a hole lock its position as readonly. I understand the "cut" solid cannot be moved, but the original cube can and the "cut" folows its position. I understand now.
