Using cba.exe as external solver for continuous beam analysis
chakkree
Postby chakkree » Tue Mar 29, 2016 5:51 am
1. Download cba from webpage http://cbeam.sourceforge.net/
2. Unzip and find "cba.exe" then copy to folder "FreeCAD_0.1x.xxx/bin".
3. Create floder to save temp file, and assign to variable "data_PATH "
4. Run Macro for test 2 span continuous beam example. using Plot module to display Bending Moment Diagram and Shear Force Diagram.
SPANS 5.8 4.2
INERTIA 3.69e-5 3.69e-5
ELASTICITY 2.1e8
CONSTRAINTS -1 0 -1 0 -1 0
LOAD 1 1 10.0 5.0 0 0
LOAD 2 1 10.0 5.0 0 0
FACTORS 1.35 1.5
import Plot
import subprocess
data_PATH = "D:\\your_data_path\\cba\\"
ContBeam1 = {
   'SPANS': [ 5.8 , 4.2] ,
   'INERTIA' : [3.69e-5,3.69e-5 ],
   'ELASTICITY' : 2.1e8 ,
   'CONSTRAINTS' : [ [-1,0] , [-1,0] ,[-1,0] ] ,
   'LOAD' : [
       [  1 ,  1 , 10.0 , 5.0 , 0 , 0] ,
       [  2 ,  1 , 10.0 , 5.0 , 0 , 0]
   'FACTORS' : { 'DL':1.35 , 'LL':1.5 }
def make_cba_inputTextFile(contBeam):
    text1 = "SPANS"
    for L in contBeam['SPANS']:
        text1 += ' {}'.format(L)
    text1 += '\n'
    text1 += "INERTIA"
    for I in contBeam['INERTIA']:
        text1 += ' {}'.format(I)
    text1 += '\n'
    text1 += "INERTIA {}".format(contBeam['ELASTICITY'])
    text1 += '\n'
    text1 += "CONSTRAINTS"
    for retrain in contBeam['CONSTRAINTS']:
        text1 += ' {} {}'.format( retrain[0] , retrain[1])
    text1 += '\n'
    for Load in contBeam['LOAD']:
        text1 += "LOAD"
        #text1 += ' {} {} {} {} {} {}' .format( Load[0] , Load[1] )
        for i in Load:
            text1 += ' {}'.format(i)
        text1 += '\n'
    text1 += "FACTORS {} {}".format( contBeam['FACTORS']['DL'] , contBeam['FACTORS']['LL'])
    text1 += '\n'
    return text1
#txt1 = make_cba_inputTextFile(ContBeam1)
inputFile = data_PATH + 'tempCBA.cba'
outputFile = data_PATH + 'tempCBA.out'
plotFile = data_PATH + 'tempCBA.plt'
f = open(inputFile, 'w')
f.write(make_cba_inputTextFile(ContBeam1))
f.close()
subprocess.call( ['cba.exe'  , '-i' , inputFile , '-o' , outputFile , '-p' , plotFile ] , shell=True )
f = open(plotFile)
lines =f.read().split('\n')
f.close()
lines.pop(0); lines.pop(0); lines.pop(-1)  ## delete 2 first rows
#x   Mdmax   Mdmin   Vdmax   Vdmin   dmax   dmin
x = []
Mdmax = []
Mdmin = []
Vdmax = []
Vdmin = []
dmax = []
dmin = []
for i in lines:
    data=i.split()
    x.append(  float (data[0]) )
    Mdmax.append( float (data[1]) ); Mdmin.append( float (data[2]) )
    Vdmax.append( float (data[3]) ); Vdmin.append( float (data[4]) )
    dmax.append( float (data[5]) ); dmin.append( float (data[6]) )
#Plot.figure("Continuous Beam Analysis Result")
Plot.figure("BMD")
Plot.plot(x,Mdmax) ; Plot.plot(x,Mdmin)
Plot.figure("SFD")
Plot.plot(x,Vdmax) ; Plot.plot(x,Vdmin)
Plot.figure("Deflections")
Plot.plot(x,dmax) ; Plot.plot(x,dmin)
OS: Windows 8
Version: 0.16.6668 (Git)
Python version: 2.7.8
chakkree
Re: Using cba.exe as external solver for continuous beam analysis
Postby chakkree » Sun Jan 08, 2017 12:12 pm
Not Complete. ContBeam.cba can show beam and support(Ry only).
Next, try to read output file to a result properties and use for display analysis results.
   ContBeam.py  --- Version 0.1.20170108
   cba -- continuous beam analysis
import FreeCAD , Part
from FreeCAD import Vector
from math import radians
class cba:
    def __init__(self,obj):
        obj.addProperty("App::PropertyFloatList","Spans","cba","Length of the cont beam spans").Spans=[4,4]
        obj.addProperty("App::PropertyStringList","Constraints","cba","Constraints of the cont beam").Constraints=['-1 0','-1 0' ,'-1 0']
        obj.addProperty("App::PropertyStringList","Loads","cba","Loads of the cont beam").Loads=['1 1 1000.0  0 0 0','1 1 1000.0  0 0 0' ]
        obj.addProperty("App::PropertyFloatList","Inertia","cba","Inertia of the cont beam").Inertia=[0.2*0.4**2/12. , 0.2*0.4**2/12.]
        obj.addProperty("App::PropertyFloat","E","cba","ELASTICITY of the cont beam").E=2.04e6*100*100
        obj.addProperty("App::PropertyFloatList","Factor","cba","Factor = DL+ LL ").Factor=[1.0,1.0]
        obj.addProperty("App::PropertyFloatList","x","results","x").x=[]
        obj.addProperty("App::PropertyFloatList","Mmin","results","Mmin").Mmin=[]
        obj.addProperty("App::PropertyFloatList","Mmax","results","Mmin").Mmax=[]
        obj.addProperty("App::PropertyFloatList","Vmin","results","Vmin").Vmin=[]
        obj.addProperty("App::PropertyFloatList","Vmax","results","Vmin").Vmax=[]
        obj.addProperty("App::PropertyFloatList","dmin","results","dmin").dmin=[]
        obj.addProperty("App::PropertyFloatList","dmax","results","dmin").dmax=[]
        obj.setEditorMode("x", 1)
        obj.setEditorMode("Mmin", 1); obj.setEditorMode("Mmax", 1)
        obj.setEditorMode("Vmin", 1); obj.setEditorMode("Vmax", 1)
        obj.setEditorMode("dmin", 1); obj.setEditorMode("dmax", 1)
        obj.Proxy = self
    def execute(self, obj):
        geom = []
        line =Part.LineSegment( Vector(0,0,0),Vector(sum(obj.Spans)*1000,0,0)  )
        geom.append(line.toShape())
        # support Ry only
        restY = int(obj.Constraints[0].split()[0])
        if restY!=0:
            r1 = Part.makeCone(50,0,100,Vector(0,0,-100))
            geom.append(r1)
        x = 0.0
        for i in range(1, len(obj.Constraints)):
            restY = int(obj.Constraints[i].split()[0])
            x += float( obj.Spans[i-1] )
            Msg('%d  %d  %f  \n'%(i,restY,x) );
            if restY!=0:
                iSup = Part.makeCone(50,0,100,Vector(x*1000,0,-100))
                geom.append(iSup)
        # Load
        for iStr in obj.Loads:
            #Msg(iStr)
            iLoad = iStr.strip().split()
            Msg(iLoad)
            Msg('\n')
        compound = Part.Compound(geom)
        compound.Placement = obj.Placement
        #obj.Shape = line.toShape()
        obj.Shape = compound
class ViewProvider_cba:
    def __init__(self, obj):
        "Set this object to the proxy object of the actual view provider"
        obj.addProperty("App::PropertyColor","Color","Octahedron","Color of the octahedron").Color=(1.0,0.0,0.0)
        obj.Proxy = self
def makeContBeam(name='cba' , SPANS=[3,3]):
    a=FreeCAD.ActiveDocument.addObject("Part::FeaturePython",name)
    cba(a)
    cba.Spans =SPANS
    ViewProvider_cba(a.ViewObject)
    return a
if __name__=='__main__':
    cBeam_Line1 = makeContBeam('cBeam_Line1' , [4,4])
    cBeam_Line2 = makeContBeam('cBeam_Line2' , [4,4] )
    cBeam_Line2.Placement.Base.y=4000
    cBeam_Line3 = makeContBeam('cBeam_Line3' , [4,4] )
    cBeam_Line3.Placement.Base.y=8000
    cBeam_LineA = makeContBeam('cBeam_LineA' , [4,4])
    cBeam_LineA.Placement.Rotation.Angle=radians(90)
    cBeam_LineB = makeContBeam('cBeam_LineB' , [4,4] )
    cBeam_LineB.Placement.Rotation.Angle=radians(90)
    cBeam_LineB.Placement.Base.x=4000
    cBeam_LineC = makeContBeam('cBeam_LineC' , [4,4] )
    cBeam_LineC.Placement.Rotation.Angle=radians(90)
    cBeam_LineC.Placement.Base.x=8000
    FreeCAD.ActiveDocument.recompute()
    Msg('Done!!\n\n')
result.
