some image of my first 3D printed Part with Freecad, and that's a part for my 3D printer....
here above the graph for the design. quite not a "standard" linear design, but an horizontal one.
No External geometry link, but indeed a Big Thank to the WorkFeature macro! it allows a lot of quick modification by manually doing projection into sketch, and nothings break when One modification is done.
(well except for filleting....)
and of course the part
note this little detail, which I thought was a graphical bug, but indeed it's on the part .... fillets....
OS: Linux
Version: 0.16.6688 (Git)
Build type: None
Hash: 7ee0afbf7ac26dadb391e277a9ce278e3c4bee4c
Python version: 2.7.9
Qt version: 4.8.6
OCC version: 6.7.0
3D Printer Improvement
Re: 3D Printer Improvement
Hello nemesis,
That's a very cool looking complex part.
I really need to resurrect my AO-100 (MendelMax-based) 3D printer!
By the way:
Fillets are often annoyingly fussy... At least you were apparently able to generate a valid STL file.nemesis wrote:note this little detail, which I thought was a graphical bug, but indeed it's on the part .... fillets....
By the way:
You are a few commits behind the last release, which is 0.16.6703.nemesis wrote:Version: 0.16.6688 (Git)
indeed, the truth is I'm working with 2 system.NormandC wrote:You are a few commits behind the last release, which is 0.16.6703.
the part are mainly designed on this one:
OS: Mac OS X
Version: 0.16.6704 (Git)
Branch: (detached from 0c449d7)
Hash: 0c449d7e8f9b2b1fb93e3f8d1865e2f59d7ed253
Python version: 2.7.11
Coin version: 3.1.3
OCC version: 6.8.0.oce-0.17
I switch to Debian on a Virtual machine when I start Filleting... due to this Bug on OS X (well It seems only present on OSX.
in fact I test 0.17 on OS X, with OCC7.0 and with this version I have no crash.
but for a full design, 0.17 and part design Next or still too young.
I test it time to time, as I really like the new workflow, but wait for the OCC7 merging in master...
even with this false graphical bug, the check of geometry shows no error. that's a bad fillet result, but a good surface lolAt least you were apparently able to generate a valid STL file.
For Sure!I really need to resurrect my AO-100 (MendelMax-based) 3D printer!
