Export FreeCAD to WebGL and Test run Augmented Reality
chakkree
Post by chakkree »
From "Augmented Reality For the Web", threex.webar. as link https://github.com/jeromeetienne/threex.webar
I exported FreeCAD model to WebGL, then use NotePad++ copy code from output file and replace to Part that added an object in the markerObject3D. Replace variable named "scene" in WebGL to "markerObject3D"
The Model example size is very small because a width of a marker is 1 unit equal to 1 unit in WebGL export file. That cause my model only about 3 mm.
TestModelHome03.FCStd
(90.11 KiB) Downloaded 103 times
I'm hard to explain. get the Code. (อธิบายด้วยภาษาไทยยังยากเลย ภาษาอังกฤษยิ่งยากขึ้นไปอีก :P)
TestFreeCAD2AR.zip
(196.33 KiB) Downloaded 130 times
In future, I think FreeCAD can export to play on Augmented Reality.
chakkree
Re: Export FreeCAD to WebGL and Test run Augmented Reality
Post by chakkree »
Test Augmented Reality.
https://www.jCivil.com/freecad/AR/test/ ... eeCAD.html
OK! the demo can work, WebRTC wants to use https.
I upload the Zip file to the web host and unzip for a test.
show the marker on webcam, you can see the model display on the marker.
1.Print the marker from http://terpconnect.umd.edu/~jwelsh12/en ... ergen.html
2. Or use marker display on mobile http://terpconnect.umd.edu/~jwelsh12/en ... ding_mm=10
rockn
Post by rockn »
:o :shock: This is working so great ! Well done :)
Working on Chromium 51.0,
Not working on Firefox 47.0 (lacking of MediaStreamTrack.getSources() )
chakkree
Post by chakkree »
Test on my Android phone.
chakkree
Post by chakkree »
@RockN Prepared for the future.
Enhancing FreeCAD(BIM) with Augmented Reality. :lol:
triplus
Post by triplus »
Looking good.
