Dimensioning in Spreadsheet
Hi, in the help forum we see a lot of questions about dimensioning in a spreadsheet. I created a red spotted ball without a dimension in the sketches. Here is the spreadsheet.
This creates my ball, I can change all dimensions in the spreadsheet and the ball changes the same
With the data from the spreadsheet I create in fact two different shapes as you can see here
The FCstd file is also attached so everybody who wants can play with it.- Attachments
- Ball.fcstd
- (59.4 KiB) Downloaded 219 times
Re: Dimensioning in Spreadsheet
Thank you for sharing this!!! Using your example and some trial and error i final have a good idea of how to use both the functions and the spread sheet in free cad. I have made a model that uses 3 dimensions from a table in a spread sheet to make both a male and female Morse taper in any size from #0 to #7. This is a very powerful and useful tool.
Linden
Seconded. Thanks for sharing, this was very useful to understand how you built the whole thing and how to use spreadsheets !
I like simple models, yet intriguing, where something can be learned - thank you. Could you explain why you need a Clone of Common and of Cut001. Couldn't you use the originals directly?
