Acoustic guitar bridge
Chris_G
Re: Acoustic guitar bridge
Post by Chris_G »
PrzemoF wrote:@Chris_G: if code works it's good, it code works and it's clean it's very good, if code works, it's clean and matches the bigger picture (FreeCAD) it's brilliant. According to my scale your code is at least good :-)
:D
PrzemoF wrote:If you know about any weak points, crashes and so on let us know :-)
Here are a few :
- The UI is hard-coded. I think it should go in a separate QT Designer file.
- the tool can be activated several times --> strange behaviour
- what behaviour when finishing editing, if the face is part of a solid ? create a duplicate face ? replace the edited face with the new one ?
- editing point weights ( hitting 's' while grabbing points ) would need some love ( realtime display weight value / ability to reset to 1 )
- How to react when input face is a trimmed surface ( abort ? allow editing anyway ? )
- display point coordinate in UI and allow to enter numerical values.
- add ability to select rows and columns
PrzemoF wrote:A while age I saw a comment that FreeCAD is not designed to work with curvy surfaces. Now I look at the guitar bridge and that comment doesn't have a leg to stand on. :D
I agree with that comment for now. I watched all the videos of this site : http://www.aliasworkbench.com/ (very interesting) and I think there is still a long road to go :lol:
Chris
Chris_G
Post by Chris_G »
Jee-Bee wrote:it should be handy ... at least for fixing broken step files!!
Do you mean for filling gaps ?
Then I'm afraid it won't help a lot :
- many faces are ( I think ) trimmed surfaces. The Nurbs surface editor doesn't handle trimming curves.
FC doesn't yet offer the needed tools for this ( accessing the OCC Curve_on_surface : 2D curves expressed in the surface U/V coordinate system ).
I think it was a Google Summer of Code proposal : http://www.freecadweb.org/wiki/index.ph ... python_API
- snapping feature would be probably needed too
Chris
Jee-Bee
Post by Jee-Bee »
Chris_G wrote:Hi,
Chris
Hmm a pity but at least it is a step forward...
microelly2
Post by microelly2 »
Nice tool, I will read the details to get inspired.
Thank you for sharing this.
Chris
It's still a lot of work to connect trimmed surface the nice way but I think it will be possible
Chris_G
Post by Chris_G »
Bridge done !
The surface quality is very good.
It just needs a little bit of sanding one the edges ( aka "the fillet tool that NEVER fails" :lol: )
BTW, I also used FC to create the soundhole ( BOP cut of a cylinder on the body ) :
Chris
microelly2
nice to see this
PrzemoF
Post by PrzemoF »
Thanks for posting the photos!
P.S. viewtopic.php?f=24&t=6430&start=30
NormandC
Post by NormandC »
Chris, this is impressive craftsmanship. :)
I really like your bridge design. And I love the fingerboard inlay. The soundhole position is quite unconventional! I wonder how it sounds.
The sides look like East Indian Rosewood, but I'm unsure of the wood used for the tabletop. Is is koa?
Jee-Bee
Post by Jee-Bee »
It looks great!! :D but i'm happy that most bands i'm the sound tech for have normal guitars ;)
far more easy to amplify :lol:
Chris_G
Post by Chris_G »
NormandC wrote:Chris, this is impressive craftsmanship. :)
Hi Normand,
Thanks for the kind words.
About the soundhole position, I am following the road that other luthiers are tracing in the recent years ( mainly Gérard Audirac ).
The soundhole's main role is to allow air flows between the inside and the outside of the body (pressure varaitions).
The sound is mainly generated by the top surface vibrating.
And the conventional position ( if it's just a convention, let's break it ! ) is, I think, quite a lot about weakening an area of the top that is already under heavy stress.
The back and sides are Brazilian RW, and the top is curly Koa.
Jee-Bee wrote:It looks great!! :D but i'm happy that most bands i'm the sound tech for have normal guitars ;)
Hi Jee-Bee,
Well, you're right : no ready-to-use soundhole cover, no soundhole magnetic pickup ... but all the usual undersaddle pickups ( transducers / piezo ) can still be installed.
Chris
