Hello,
Here's a first study of a Structural Glazing parametric file. There is an entry spreadsheet and one of output. Virtually all components, as well as the number of horizontal and vertical modules, are configurable.
Architecture - Editable Structural Glazing
- Captura_01.PNG (17.5 KiB) Viewed 4341 times
- Entries.PNG (24.66 KiB) Viewed 4341 times
- Outputs.PNG (17.38 KiB) Viewed 4341 times
- Editable_structural_glazing.FCStd
- (55.41 KiB) Downloaded 133 times
Re: Architecture - Editable Structural Glazing
This looks real good. It is your first study of this window. I am looking forward to the next version. My advice is split the frames in parts that can be produced in a workshop. The top and bottom parts of the outer frame will than be of one piece
Very good! Excellent example of how you can do very powerful parametric objects without coding...
Hello, good job
I was testing your Structural Glazing and is fantastic.
But if we try to move it it loses the relationship between the parts (it's an old problem) I think you should try to put it in a container? I do not know exactly how, but maybe someone here can help you
congratulations,
Renato
congratulations,
Renato
my native language is not English, please excuse me any incorrectness, I apologize for any inconvenience caused, thank you
About moving or rotating, inserting the element in a new part of FreeCAD 0.17 you can move and rotate without problem, through the Properties window. I do not deeply immersed in this new version and do not know if this is the correct way to work with the new part. I believe that those developed it can clarify.
I take this opportunity to express the wish that also include any suggestion in this forum for share the files resulting.
Thank you for your comments!
- Mover e girar.jpg (452.29 KiB) Viewed 4185 times
yes, but if you move with the mouse ...
is it a bug?
Renato
is it a bug?
Renato
Renato,
There is a way to do the necessary changes for a real work (FreeCAD 0.16): clone and/or make simple copies of the structural glazing, this permits make any changes without problem. Here is a example of cloning (the four horizontal modules façades) and coping (the three modules façades).
- Clonar,copiar,mover e girar.png (185.37 KiB) Viewed 3946 times
