Test read data from Frame3DD file.
bernd
Re: Test read data from Frame3DD file.
Postby bernd » Mon Jan 02, 2017 2:50 pm
attached a truss calculated by FreeCAD FEM with z88 and CalculiX ...
fem-truss.fcstd
(50.32 KiB) Downloaded 8 times
bernd
Postby bernd » Mon Jan 02, 2017 2:53 pm
@chakkree:
If you would convert the data into FEM workbench data we could add Framme3DD as another solver for FEM for line meshes.
bernd
Postby bernd » Mon Jan 02, 2017 8:10 pm
bernd wrote:@chakkree:
Most important would be to create a FEM mesh out of the geometry data during import. This is not difficult to do. See http://www.freecadweb.org/wiki/index.ph ... _py_python
As an example attached the python code to produce the mesh of the truss I have shown in the post before:
# Created by FreeCAD Python FEM mesh exporter
import Fem
femmesh = Fem.FemMesh()
# nodes
femmesh.addNode(0.0, 2000.0, 0.0, 1)
femmesh.addNode(0.0, 0.0, 0.0, 2)
femmesh.addNode(1000.0, 1000.0, 2000.0, 3)
femmesh.addNode(2000.0, 2000.0, 0.0, 4)
femmesh.addNode(2000.0, 0.0, 0.0, 5)
femmesh.addNode(3000.0, 1000.0, 2000.0, 6)
femmesh.addNode(4000.0, 2000.0, 0.0, 7)
femmesh.addNode(4000.0, 0.0, 0.0, 8)
femmesh.addNode(5000.0, 1000.0, 2000.0, 9)
femmesh.addNode(6000.0, 2000.0, 0.0, 10)
femmesh.addNode(6000.0, 0.0, 0.0, 11)
femmesh.addNode(7000.0, 1000.0, 2000.0, 12)
femmesh.addNode(8000.0, 2000.0, 0.0, 13)
femmesh.addNode(8000.0, 0.0, 0.0, 14)
femmesh.addNode(9000.0, 1000.0, 2000.0, 15)
femmesh.addNode(10000.0, 2000.0, 0.0, 16)
femmesh.addNode(10000.0, 0.0, 0.0, 17)
femmesh.addNode(11000.0, 1000.0, 2000.0, 18)
femmesh.addNode(12000.0, 2000.0, 0.0, 19)
femmesh.addNode(12000.0, 0.0, 0.0, 20)
# elements
femmesh.addEdge([1, 2], 1)
femmesh.addEdge([4, 5], 2)
femmesh.addEdge([7, 8], 3)
femmesh.addEdge([10, 11], 4)
femmesh.addEdge([13, 14], 5)
femmesh.addEdge([16, 17], 6)
femmesh.addEdge([19, 20], 7)
femmesh.addEdge([1, 4], 8)
femmesh.addEdge([2, 5], 9)
femmesh.addEdge([4, 7], 10)
femmesh.addEdge([5, 8], 11)
femmesh.addEdge([7, 10], 12)
femmesh.addEdge([8, 11], 13)
femmesh.addEdge([10, 13], 14)
femmesh.addEdge([11, 14], 15)
femmesh.addEdge([13, 16], 16)
femmesh.addEdge([14, 17], 17)
femmesh.addEdge([16, 19], 18)
femmesh.addEdge([17, 20], 19)
femmesh.addEdge([1, 3], 20)
femmesh.addEdge([4, 6], 21)
femmesh.addEdge([7, 9], 22)
femmesh.addEdge([10, 12], 23)
femmesh.addEdge([13, 15], 24)
femmesh.addEdge([16, 18], 25)
femmesh.addEdge([2, 3], 26)
femmesh.addEdge([5, 6], 27)
femmesh.addEdge([8, 9], 28)
femmesh.addEdge([11, 12], 29)
femmesh.addEdge([14, 15], 30)
femmesh.addEdge([17, 18], 31)
femmesh.addEdge([3, 4], 32)
femmesh.addEdge([6, 7], 33)
femmesh.addEdge([9, 10], 34)
femmesh.addEdge([12, 13], 35)
femmesh.addEdge([15, 16], 36)
femmesh.addEdge([18, 19], 37)
femmesh.addEdge([3, 5], 38)
femmesh.addEdge([6, 8], 39)
femmesh.addEdge([9, 11], 40)
femmesh.addEdge([12, 14], 41)
femmesh.addEdge([15, 17], 42)
femmesh.addEdge([18, 20], 43)
femmesh.addEdge([3, 6], 44)
femmesh.addEdge([6, 9], 45)
femmesh.addEdge([9, 12], 46)
femmesh.addEdge([12, 15], 47)
femmesh.addEdge([15, 18], 48)
femmesh.addEdge([2, 4], 49)
femmesh.addEdge([5, 7], 50)
femmesh.addEdge([8, 10], 51)
femmesh.addEdge([11, 13], 52)
femmesh.addEdge([14, 16], 53)
femmesh.addEdge([17, 19], 54)
# show FEM mesh
Fem.show(femmesh)
Gui.activeDocument().activeView().viewAxonometric()
Gui.SendMsgToActiveView("ViewFit")
yorik
Site Admin
Postby yorik » Tue Jan 03, 2017 1:45 am
Wow, I could create such a mesh easily out of the Arch structural objects...
chakkree
Postby chakkree » Tue Jan 03, 2017 3:22 pm
@Bernd Thank you so much for your 1D element example. I'll learn FEM WB from a tutorial.
chakkree
Postby chakkree » Tue Jan 03, 2017 4:11 pm
test using FEM line mesh for display nodes and elements.
   Version4
   use FEM Mesh for display nodes and elements
import FreeCADGui
import Fem
class Node:
    def __init__(self, id , x,y,z):
        self.x = x
        self.y = y
        self.z = z
        self.id = str(id)
# elmnt n1     n2    Ax     Asy     Asz     Jx     Iy     Iz     E     G     roll  density
class Member:
    def __init__(self, id , n1,n2):
        self.n1 = n1
        self.n2 = n2
        self.id = str(id)
NodeList = {}
MemberList = {}
ProjectDescription = ''
numNode = 0
path = 'D:\\StructurallAnalysis\\Frame3DD\\Data\\'
#factor = 25.42  ; fName = 'exA.3dd'
#factor = 1.0  ;fName = 'exB.3dd'
#factor = 25.42  ; fName = 'exC.3dd'
#factor = 25.42  ; fName = 'exD.3dd'
factor = 25.42  ; fName = 'exE.3dd'
#factor = 25.42  ; fName = 'exG.3dd'
#factor = 25.42  ; fName = 'exH.3dd'
#factor = 25.42  ; fName ='exI.3dd'
#factor = 1.0  ; fName = 'exJ.3dd'
# read file to list
lines = [line.rstrip('\n') for line in open(path+fName)]
# strip remark #
lines2 = []
for iLine in lines:
    pos = iLine.find('#')
    if pos>-1:
        lines2.append( iLine[:pos] )
    else:
        lines2.append( iLine )
# remove blank line
lines3 = []
for iLine in lines2:
    if len(iLine.strip())>0:
        lines3.append(iLine)
#for iLine in lines3:
#    Msg(iLine); Msg('\n')
ProjectDescription = lines3[0]
numNode = int(  lines3[1] )
numReactions = int(  lines3[numNode +2] )
numMembers = int(  lines3[numNode+ numReactions +3] )
Msg('numNode = %d\n'% numNode);
Msg('numReactions = %d\n'% numReactions);
Msg('numMembers = %d\n'% numMembers);
for i in range(0, numNode):
    dataNode = lines3[i+2].split()
    NodeList[dataNode[0]] =  Node(dataNode[0] ,
              float(dataNode[1]) ,float( dataNode[2]) , float( dataNode[3]) )
for i in range(0, numMembers):
    dataMember = lines3[i+numNode+ numReactions +4].split()
    MemberList[dataMember[0]] =  Member(dataMember[0] ,dataMember[1] , dataMember[2])
# nodes
for id in NodeList: # node
    femmesh.addNode(NodeList[id].x*factor,NodeList[id].y*factor,NodeList[id].z*factor, int(id) )
# elements
for id in MemberList:
    n1 = MemberList[id].n1
    n2 = MemberList[id].n2
    femmesh.addEdge([int(n1), int(n2)], int(id))
# show FEM mesh
obj = App.ActiveDocument.addObject("Fem::FemMeshObject",fName)
obj.FemMesh = femmesh
obj.ViewObject.DisplayMode = u"Faces, Wireframe & Nodes"
obj.ViewObject.PointColor = (0.667,0.000,0.000)
obj.ViewObject.PointSize = 7.000
FreeCADGui.activeDocument().activeView().viewAxonometric()
FreeCADGui.SendMsgToActiveView("ViewFit")
Result:
TestReadFile2Mesh.FCStd
(11.51 KiB) Downloaded 6 times
bernd
Postby bernd » Wed Jan 04, 2017 5:52 am
bonfire soup pan frame ...
bonfire_soup_pan_frame.fcstd
(15.23 KiB) Downloaded 6 times
bernd
Postby bernd » Wed Jan 04, 2017 5:56 am
ATM only trusses are supported in FreeCAD line analysis for Z88. CalculiX has some limitation too. If a edge normal is in z-direction a extra direction parameter needs to be defined in the line mesh analysis. This is not supported by FreeCADs inp file writer ATM.
We may should really try to get Frame3DD running in conjunction with FreeCAD FEM.
We are able to import the mesh and the geometry. We are able to define fixes (supports) and loads in FEM already. What is needed it to export the Frame3DD file format out of the FEM mesh and the FEM constraint data and call Frame3DD to run the analysis on this file.
@chakkree:
the z88 mesh exporter and importer shows how such an mesh export and import in FEM could look like. https://github.com/FreeCAD/FreeCAD/blob ... Z88Mesh.py and git commit d96ead In our case we only have seg2 elements (FEM_Mesh)
ulrich1a
Postby ulrich1a » Wed Jan 04, 2017 1:42 pm
bernd wrote:CalculiX has some limitation too. If a edge normal is in z-direction an extra direction parameter needs to be defined in the line mesh analysis. This is not supported by FreeCADs inp file writer ATM.
I would expect, that this or something equivalent is needed in any serious frame-analysis software. Otherwise one cannot determine the orientation of a non quadratic beam cross-section. But this is essential to calculate the bending right.
Ulrich
bernd
Postby bernd » Wed Jan 04, 2017 4:43 pm
Ahh thats not the problem. Even on circle cross section the problem exists. It's another problem If the direction of an edge goes into z-direction and only if it goes in global z-direction an direction parameter in CalculiX has to be set. This because this direction parameter goes into z-direction and this parameter should not go in the same direction the the edge member. Just try an simple line mesh in global z-direction.
