Madeleine de Course Stellaire No16
emills2
Re: Madeleine de Course Stellaire No16
Post by emills2 »
ok...i will do what i can to update icons and filenames to match the currently functioning macros by Friday.
I just had a quick look around and realized that i let the repo organization drift to the point where i even i have a hard time finding thing :?
It's definitely more fun to write new stuff than to maintain existing stuff :D
triplus
Post by triplus »
Yes having proper icons would be cool. ;)
If you will provide that first thing i will do is create a set of macro commands on the toolbar. And after test them.
emills2
Post by emills2 »
i started a tutorial. It is useful to get through setup at least. This is only for 2 of the macros, so you can get a feel for the tools without spending an hour making toolbars.
edit:fixed url
https://github.com/edwardvmills/NURBSli ... cCurve4.md
i only need an hour or two more of work on it, so it should be done this friday.
if you want to get ahead of that...i did make a few new icons, so here is the recommended setup. Highlighted are the 2 macros used in the tutorial above:
Tutorial 0.01 setup - ControlPoly4 and CubicCurve4.PNG (84.95 KiB) Viewed 1982 times
still missing 4 icons, but i think it should be bearable.
If you want to look at existing models, look in https://github.com/edwardvmills/NURBSli ... 0to%200.17
Since i had to make some drastic changes going from 0.16 to 0.17, i have no idea which ones of the older models still work.
emills2
Post by emills2 »
tutorial more or less complete.
edit:fixed url
I think it is ready aside from typos. It gives good coverage of just two macros, so you get a lot of mileage for very little setup time.
I hope you like it. If Someone posts screenshots of actual curve models made with it, i'll write the next tutorial: ControlGrid44 and CubicSurface44!
triplus
Post by triplus »
Thanks will go over everything at weekend.
P.S. Likely we should open new thread to discuss this further.
triplus
Post by triplus »
P.S. Waiting for the Tutorial_0.02.
emills2
Post by emills2 »
:D
A user! Most excellent.
Tutorial 0.02 on the way.
I will post the link in the macro forum tho, this conversation doesn't belong here.
emills2
Post by emills2 »
edited tutorial file name, here's a new link
working on 0.02
posted notice here so the link doesn't die without an explanation
edit: fixed urls in previous links....since 9 persons tried to go the old link after i posted the new ones
triplus
Post by triplus »
