Voxel Workbench
kkremitzki
Re: Voxel Workbench
Postby kkremitzki » Sun Feb 19, 2017 11:53 am
kkremitzki wrote:It looks like the file is not actually available via HTTPS on their server. The fix then would be to copy http://phpbbex.com/api/bbmedia.js onto freecadweb.org via FTP and update the forum [video] macro once more to point to wherever you store it, making sure to do it like src="//freecadweb.org/path/to/bbmedia.js"
yorik wrote:ping
Yorik I uploaded bbmedia.js onto freecadweb.org/js/bbmedia.js but I don't have access to update the bbcode for video in the admin panel. When you get a chance can you update the source as I described in my self-quote?
yorik
Site Admin
Re: Voxel Workbench
Postby yorik » Mon Feb 20, 2017 9:59 pm
kkremitzki wrote:Yorik I uploaded bbmedia.js onto freecadweb.org/js/bbmedia.js but I don't have access to update the bbcode for video in the admin panel. When you get a chance can you update the source as I described in my self-quote?
it is done already...
kkremitzki
Re: Voxel Workbench
Postby kkremitzki » Mon Feb 20, 2017 10:04 pm
It might look like that because I tried updating it directly through the database (bad me...) but I think some other code runs when it's updating correctly through the UI, because the page is still showing it loading from the original site. Can you try just hitting "apply" again and see if that helps?
yorik
Site Admin
Re: Voxel Workbench
Postby yorik » Tue Feb 21, 2017 1:39 pm
kkremitzki wrote:Can you try just hitting "apply" again and see if that helps?
Done. Maybe we can also try to put the js file in the forum.freecadweb.org subdomain?
