The male CADDer's most basic needs in life, ..... food....sex....and of course a Helix!yorikvanhavre wrote:the kwahoo spring will become famous in history, a bit like the pythagore theorem or the columbus egg... Generations of students will study it and try to reproduce
This is a steel Universal Beam (often referred to as an RSJ) modelled to the Australian standard. The size is 250UB37. This means 250mm high over all, Universal Beam (there is also a Universal Column in the Australian Standard) and approximately 37Kg/m.
Modelled in FreeCAD PartDesign, padded sketch 1m long.
The Australian standards data came from this web site below: -
http://www.steelweb.info/
http://www.steelweb.info/info.htm
http://www.steelweb.info/250UB37.htm
Here is a JPEG file the FreeCAD file and an SVG file (note the render is not perfect, I think the artefacts are related to the lighting?? in FreeCAD??) The SVG is "3D rendered from FreeCAD" pop up option. Regards
Jim
