Inline-four engine animation
clintonsam75
Re: Inline-four engine animation
Postby clintonsam75 » Fri Nov 14, 2014 5:35 am
Thanks a lot, peterl94.
So here is exactly what to do. Step by step.
First create a python file called conrod.py and save it in the macro directory.
Then open crank_simul.fcstd in FreeCAD.
Next, down in the python console, type "from conrod import *" without the quotes.
Finally, type "animation.stop()" without the quotes which will stop the animation.
To start it again, you can just type "animation = Animation()" to start the animation over from the beginning or type "animation.timer.start(50)" to continue the animation from where you stopped it.
peterl94
Postby peterl94 » Fri Nov 14, 2014 7:35 am
clintonsam75 wrote:After that, start the macro which will start the animation.
Actually, I don't think you would want to do this. The animation will start when you run the import command in the console.
clintonsam75
Postby clintonsam75 » Fri Nov 14, 2014 9:08 am
You're right again. I'll edit that step out.
