#619 Made TreeView stable
Merged, abandoned or rejected pull requests are moved here to clear the main Pull Requests forum.
realthunder
Re: #619 Made TreeView stable
Post by realthunder »
wmayer wrote:Today I found a major performance regression with the new tree view. In issue #1999 you will find the file FreeCadProblem.step which takes 15 minutes to load in release mode.
Mantis is down at the moment. Could you please post the step file here, or if it is too big, send it to my email?
Try Assembly3 with my custom build of FreeCAD at here.
Founder
Post by wmayer »
Here it is.
FreeCadProblem.7z
(182.53 KiB) Downloaded 75 times
realthunder
wmayer wrote:Here it is.
It is because of the cyclic check on adding object. This is the worst case I've predicated, all children first. But obviously I am wrong about the performance impact. Only 900 object, and it's that slow. I've submitted the fix.
Founder
Post by wmayer »
Thanks for looking at this issue. Unfortunately your patch doesn't change anything. The load time of the STEP file is still at ~15 minutes.
realthunder
wmayer wrote:Thanks for looking at this issue. Unfortunately your patch doesn't change anything. The load time of the STEP file is still at ~15 minutes.
That's odd. You're right, it didn't make a difference, because I reverted the change and it is still fast on my machine! How did you load the file, by just opening it using FC?
realthunder
Even debug build is fast. What OS are you using?
Founder
Post by wmayer »
By drag'n'drop into the FreeCAD main window. Reading and transferring the STEP is fast (which isn't influenced by the tree) but when adding the part objects to the part container then this step is very slow (something like O(n^2) I guess).
IMO, the problem is inside DocumentItem::populateItem where you first remove all children of an item and then add them again step-by-step. And this is also done when any kind of property has been changed -- not only link properties. This makes it somewhat inefficient and would explain the quadratic runtime.
Btw,
OS: Windows 7
Version: 0.17.10680 +1 (Git)
Branch: pr670
Hash: 802c3480fbbc6445331511633ae8ab8fd52413e8
Python version: 2.7.8
OCC version: 7.0.0
DeepSOIC
Post by DeepSOIC »
I have tried opening the step in:
Version: 0.17.10665 (Git)
Hash: 47847513a85ff6615774ef628230f79e37471daf
OCC version: 7.0.0
First time, progress bar filled quite quickly, but then it started from beginning, and looked like stuck for about a minute. Then I just killed FreeCAD.
I opened the step by double-clicking file (i.e., like through command line FreeCAD path\to\file.step).
realthunder
wmayer wrote:By drag'n'drop into the FreeCAD main window. Reading and transferring the STEP is fast (which isn't influenced by the tree) but when adding the part objects to the part container then this step is very slow (something like O(n^2) I guess).
I just drag and drop, and it is fast. In Debug mode, it took less than 20 second on my machine. So it is a Windows issue, that will be very unexpected if so. I'll try and see.
DeepSOIC wrote:First time, progress bar filled quite quickly, but then it started from beginning, and looked like stuck for about a minute. Then I just killed FreeCAD
Yes, it is a two stage thing. The second stage locks the GUI, and took about 20 seconds on my machine.
realthunder
Yep, it is happening on my Windows, too. Six minutes now, still no response. Ahh...I hate Windows. It's probably Qt's fault though. I'll try to avoid take all children and see.
