Can FreeCAD convert adjacent faces to an arc?
If I have several small faces side by side roughly describing an arc, is there a way to replace them with an arc plotted through the edges and/or vertexes of those faces?
Re: Can FreeCAD convert adjacent faces to an arc?
The object you are talking about is it a mesh or a part shape, i.e. a cad model?
In case it's a part shape we have a function accessible via Python to do this but currently there is no way to do it with the GUI.
The Part function will approximate to a bspline, right? I wonder if there would be a good method to approximate to an arc... Maybe just take 3 points of a wire?
The function is called replaceShape and the replacement shape can be everything, not just a b-spline. However, using this function is not easy because it works very low-level which means that depending on the model you have to replace wires, edges or vertexes too.
One more FreeCAD secret I didn't know!
Right now it's a simple, flat, profile shape. 1 face each top and bottom - same shape, connected with multiple flat and vertical rectangular faces.
The largest vertical faces need to stay flat. The ones I want to replace with curves, arcs, splines - whatever Heeks can translate to efficient curvy G-code - are the ones that approximate curves.
One characteristic separating the flat VS wannabe curves is the ones to remain flat are wider than they are tall and the others are taller than they are wide.
What could be done with this shape is delete one horizontal face then select the points to be curve-verted convert them then extrude back to the height of the original 3D model.
I think an example would be helpful.
Here's an example file.
- striker-test - Copy.rar
- (85.05 KiB) Downloaded 34 times
hi
is what these two macro meet your needs ?
Macro_cutLine
Macro_cutCircle
they are included in the macro Macro_WorkFeatures
the original object is not modified
mario
Macro_cutLine
Macro_cutCircle
mario
How about some exact instructions on how to install your Work Feature addon? I found the macro folder and unzipped it to there. Now how do I make it actually work?
