FreeCAD hangs when using Draft Dimension
Re: FreeCAD hangs when using Draft Dimension
I have the same issue. Here are the steps I used.
1. Start FreeCAD, create a new file.
2. Create a 1x1x1 cube.
3. Open the Draft workbench and select the dimension tooll
4. Click the points at the ends of an edge, FreeCAD freezes.
The same occurs when the "edge" feature is used.
OS: Windows 7
Word size of FreeCAD: 32-bit
Version: 0.15.4671 (Git)
Branch: releases/FreeCAD-0-15
Hash: 244b3aef360841646cbfe80a1b225c8b39c8380c
Python version: 2.7.8
Qt version: 4.8.6
OS: Windows 7
Qt version: 4.8.6
No crash for me... Can you check if any of the other Draft tools also fails (ex. Rectangle or BSpline)?
After some testing, all the other tools are working correctly without freezing, it seems to be the Dimension tool exclusively. Would video of the steps and subsequent behavior be helpful?yorik wrote:No crash for me... Can you check if any of the other Draft tools also fails (ex. Rectangle or BSpline)?
Sorry for double posting, but the following text appears below the Python console in red:
Unhandled unknown exception caught in GUIApplication::notify
Also, I didn't clearly illustrate all the steps to reproduce the problem.
1. Start FreeCAD.
2. Select "Part" workbench.
3. Create parameterized cube.
4. Switch to "Draft" workbench.
5. Select Dimension tool and select corner points or hold Alt and select an edge.
6. FC freezes.
I will try it on geometry padded from a sketch and see if the behavior changes.
Edit: The behavior is exactly the same with geometry padded from sketches. I have submitted the bug to the bugtracker.
1. Start FreeCAD.
6. FC freezes.
- FreeCAD.log
- (14.99 KiB) Downloaded 40 times
I figured out what was happening and how to make it work. The "Display Mode" property on the "View" tab has to be set to 3D. Otherwise, the viewport will freeze when you try to pan or rotate. The problem is easily fixed by making 3D mode the default in the Draft preferences.
Can you try the following code in the python console of freecad and see if it crashes? It looks like an old problem that might have resurfaced...
from pivy import coin
sg = Gui.ActiveDocument.ActiveView.getSceneGraph()
t1=coin.SoAsciiText()
t1.string = "Hello"
sg.addChild(t1)
# <-- should not crash
t2=coin.SoAsciiText()
sg.addChild(t2)
# <-- should crash here, if it is what I think
Just created a new document and ran the python script, looks pretty, but no crash.
OS: Linux
Version: 0.16.5172 (Git)
Build type: Debug
Hash: 3f4e55a4745b911aeed902cd0295ca3871aad884
Python version: 2.7.10
Coin version: 3.1.3
OCC version: 6.8.0.oce-0.17
yorik wrote:Can you try the following code in the python console of freecad and see if it crashes? It looks like an old problem that might have resurfaced...Code: Select all
from pivy import coin sg = Gui.ActiveDocument.ActiveView.getSceneGraph() t1=coin.SoAsciiText() t1.string = "Hello" sg.addChild(t1) # <-- should not crash t2=coin.SoAsciiText() sg.addChild(t2) # <-- should crash here, if it is what I think
I will test it ASAP.
Ok, I tested the code and it didn't crash or freeze. It simply displayed "Hello" in the view.
Okay then that's one culprit excluded... I'll keep looking.
