Heyho,
Do the spreadsheet may work with " if then else" stuff?
Br kc
IF THEN ELSE in a spreadsheet?
Re: IF THEN ELSE in a spreadsheet?
Yes, it's similar to the conditional operator in C: <test> ? <true-branch> : <false-branch>kc79 wrote:Heyho,
Example: = (A1 > A2) ? 1 : 2
...will give 1 if A1 > A2, and 2 otherwise.
Eivind
This doesn't work in FC 0.17:
Assembly 3 notes: https://github.com/ceremcem/freecad-notes
You necrobumped a rather old topic. Consider to open a new and reference the old. Now for your issue:
Omit the brackets, i.e. write
I could have used a screenshot to show this, but writing such things as plain text has two advantages: It saves bandwith! Your image consumes 117.14 Kilobytes, which is approximately 1000 times the size some text would need.
The second reason is, that your image cannot be searched by other users having the same problem.
=B1 > 2 ? 1 : 2
Thanks Chris, that worked.chrisb wrote: ↑Sat Sep 22, 2018 2:05 pm Omit the brackets, i.e. writeCode: Select all
=B1 > 2 ? 1 : 2
Searches directly led me to the topic, so I thought someone else would also come here, which in turn made sense to resume the thread.You necrobumped a rather old topic. Consider to open a new and reference the old.
I've never seen that the bandwidth was a problem before, anyway, I had no choice this time because there were no error messages in the output. I'm filing a bug for this.I could have used a screenshot to show this, but writing such things as plain text has two advantages: It saves bandwith! Your image consumes 117.14 Kilobytes, which is approximately 1000 times the size some text would need.
In this particular context, I think previous content is quite enough for further searches (as I found the topic by google search).The second reason is, that your image cannot be searched by other users having the same problem.
Sorry for any inconvenience, it'll take some time to get used to the FreeCAD forum.
