This is normal. As DeepSOIC said, all this command does is to start the Line tool, you need to click in the 3D view. But first, you need to be in Sketch edit mode. If you are not in edit mode, nothing can happen, and the sketcher geometry toolbar will remain grayed out.jbe wrote:I try on the PC in the class room ,Gui.runCommand("Sketcher_CreateLine"), and nothing appear.
What the Task view shows is that you are not in sketch edit mode.jbe wrote:On the screnshot, you can see the error that I can not use sketch tool, after doing a new sketch.
Are you saying that after clicking on "New sketch", you are not brought into the editing mode?
Is the error message shown in your capture displayed right after you create a new sketch?
Does a Sketch label appear in the Model tree?
How? From the Daily Builds PPA?jbe wrote:After install Ubuntu, I install Freecad 0.16 this afternom.
