Hi @peterl94
for me it is working like a charm!
thx a lot
Maurice
Word size of FreeCAD: 32-bit
Version: 0.17.10133 (Git)
Hash: 686ba7094d87f7413d713ea2893c973bff29010b
Python version: 2.7.8
OCC version: 7.0.0
I tested with ProfiliQuadro-assembly-aligned-2-normal.FCStd
and with some assembly2 examples (i.e testAssembly17-bspline_objects.fcstd) that didn't worked in win and now the constrains work fine!
(tested with FC 0.17 10085 64b )
Replacing the numpy-lib in a stable 0.16.6706 Windows 64 release with the 1.12 Version, would that work or not ?
[I would assume no, because 1.12 is built against VC 2013 ?]
[Edit]
OK, I couldn't resist and tried it on my Windows 7 64-bit system.
Administrator Priviliges required.
Downloaded the provided 64-bit numpy.
Downloaded and opened with standard 0.16.6706 (64bit) the File "ProfiliQuadro-assembly-aligned-3.FCStd".
"Solve Constraints" lets the "left" profile detach from the other two profiles.
Went to "C:\Program Files\FreeCAD 0.16\bin\Lib\site-packages" and removed the "NUMPY"-folder.
Copied downloaded and extracted NUMPY-Folder there.
Restart FreeCAD, Re-Load Assembly, "Solve Constraints" - everything looking good.
Will leave the lib in place and do further tests ...
r-frank wrote:Replacing the numpy-lib in a stable 0.16.6706 Windows 64 release with the 1.12 Version, would that work or not ?
This should work 0.16 and 0.17 x64 are built with VS2013, only 0.16 x32 is built with VS2008.
