Could you try out:
sudo apt-get install libfontconfig1-dev
Reading package lists... Done
Building dependency tree
Reading state information... Done
The following additional packages will be installed:
libexpat1-dev libfreetype6-dev libpng12-dev zlib1g-dev
The following NEW packages will be installed:
libexpat1-dev libfontconfig1-dev libfreetype6-dev libpng12-dev zlib1g-dev
0 upgraded, 5 newly installed, 0 to remove and 0 not upgraded.
Need to get 2.081 kB of archives.
After this operation, 8.239 kB of additional disk space will be used.
Do you want to continue? [Y/n]
Yes.Giulio Buccini wrote:Should I go with installation?
Get:1 http://de.archive.ubuntu.com/ubuntu xenial-updates/main amd64 libexpat1-dev amd64 2.1.0-7ubuntu0.16.04.2 [115 kB]
Get:2 http://de.archive.ubuntu.com/ubuntu xenial/main amd64 zlib1g-dev amd64 1:1.2.8.dfsg-2ubuntu4 [168 kB]
Get:3 http://de.archive.ubuntu.com/ubuntu xenial/main amd64 libpng12-dev amd64 1.2.54-1ubuntu1 [184 kB]
Get:4 http://de.archive.ubuntu.com/ubuntu xenial/main amd64 libfreetype6-dev amd64 2.6.1-0.1ubuntu2 [956 kB]
Get:5 http://de.archive.ubuntu.com/ubuntu xenial-updates/main amd64 libfontconfig1-dev amd64 2.11.94-0ubuntu1.1 [658 kB]
Fetched 2.081 kB in 3s (673 kB/s)
Selecting previously unselected package libexpat1-dev:amd64.
(Reading database ... 332873 files and directories currently installed.)
Preparing to unpack .../libexpat1-dev_2.1.0-7ubuntu0.16.04.2_amd64.deb ...
Unpacking libexpat1-dev:amd64 (2.1.0-7ubuntu0.16.04.2) ...
Selecting previously unselected package zlib1g-dev:amd64.
Preparing to unpack .../zlib1g-dev_1%3a1.2.8.dfsg-2ubuntu4_amd64.deb ...
Unpacking zlib1g-dev:amd64 (1:1.2.8.dfsg-2ubuntu4) ...
Selecting previously unselected package libpng12-dev:amd64.
Preparing to unpack .../libpng12-dev_1.2.54-1ubuntu1_amd64.deb ...
Unpacking libpng12-dev:amd64 (1.2.54-1ubuntu1) ...
Selecting previously unselected package libfreetype6-dev:amd64.
Preparing to unpack .../libfreetype6-dev_2.6.1-0.1ubuntu2_amd64.deb ...
Unpacking libfreetype6-dev:amd64 (2.6.1-0.1ubuntu2) ...
Selecting previously unselected package libfontconfig1-dev:amd64.
Preparing to unpack .../libfontconfig1-dev_2.11.94-0ubuntu1.1_amd64.deb ...
Unpacking libfontconfig1-dev:amd64 (2.11.94-0ubuntu1.1) ...
Processing triggers for doc-base (0.10.7) ...
Processing 3 added doc-base files...
Registering documents with scrollkeeper...
Processing triggers for man-db (2.7.5-1) ...
Setting up libexpat1-dev:amd64 (2.1.0-7ubuntu0.16.04.2) ...
Setting up zlib1g-dev:amd64 (1:1.2.8.dfsg-2ubuntu4) ...
Setting up libpng12-dev:amd64 (1.2.54-1ubuntu1) ...
Setting up libfreetype6-dev:amd64 (2.6.1-0.1ubuntu2) ...
Setting up libfontconfig1-dev:amd64 (2.11.94-0ubuntu1.1) ...
Well open up FreeCAD and business as usual.Giulio Buccini wrote: And now?
Giulio Buccini wrote:It works!
It works!
It works!
I'm happy like a tornado in a caravan parking zone!
Well i don't have a final answer for that ATM and likely for now i won't investigate this further. As i wanted to push first release of ShortCuts out ASAP but stuff like this changes priorities a bit. My goal was to find out why some users are having issues and some not on the same system. I feel that this question was answered.So that libs was missing or what???
(I would like to update my bug report)
libfreetype6-dev is already a FreeCAD dependency on both the Daily and Stable PPAs.yorik wrote:I'm unable to reproduce the problem on my system (being 0.16 or 0.17). Most probably something missing on the Coin3D side...
This page explains how Coin locates fonts https://grey.colorado.edu/coin3d/classSoFont.html
Apparently on linux it uses the freetype library.
It could be libfontconfig1-dev, or it could be any of its dependencies:Giulio Buccini wrote:So that libs was missing or what???
Notice that libfreetype6-dev is there...Giulio Buccini wrote:Code: Select all
The following additional packages will be installed: libexpat1-dev libfreetype6-dev libpng12-dev zlib1g-dev
Did you mean the libfreetype-dev package, or just the runtime package?triplus wrote:I think i ruled freetype out earlier today
But remember that Ulrich wrote he has the same problem on a Windows 7 PC...triplus wrote:It could be Ubuntu package has issue and/or some symlink is missing.
I've been procrastinating on installing 16.04 LTS on my home desktop PC, I'll try to think about this when I do manage it...triplus wrote:For more definitive answer this would need to be investigated further.
You don't have to do that. Just remove libfontconfig1-dev on your Ubuntu 14.04 install and it will stop working. Likely the same behaviour can be observed on Ubuntu 12.04.NormandC wrote:I've been procrastinating on installing 16.04 LTS on my home desktop PC, I'll try to think about this when I do manage it...
sudo ln -s /usr/lib/x86_64-linux-gnu/libfontconfig.so.1 /usr/lib/libfontconfig.so
sudo ln -s /usr/lib/i386-linux-gnu/libfontconfig.so.1 /usr/lib/libfontconfig.so
ln -s /usr/lib/$(DEB_HOST_MULTIARCH)/libfontconfig.so.1 /usr/lib/libfontconfig.so
