OS: Windows 7
Version: 0.16.6706 (Git)
Branch: releases/FreeCAD-0-16
Python version: 2.7.8
OCC version: 6.8.0.oce-0.17
I've also had the Icons Not Found issue after customizing a ToolBar. With a search, I found this Topic, and also this one (viewtopic.php?t=8179) which seem to address the issue. Is there currently a better solution to this issue than either editing the Python script, creating a Macro (neither of which I know how to do yet), or manually opening the relevant WorkBenches prior to opening the WB with my customized ToolBar?
After customizing my ToolBar:
After reopening FreeCad:
If I have Part WB as my autoload on Start, then if I go to Arch or OpenSCAD afterwards, the icons are X there as well.
Since Parameter Editor was mentioned as a solution, here is what it currently looks like.
I tried changing from "ArchCommands" to "ArchTools", clicking "save to disk", and reopening FC, and it just changed it back. Then I tried changing to just "Arch", which seemed to work for the Survey icon, but if I do the same to "OpenSCAD", it deletes the Refine icon from the custom toolbar altogether.
[SOLVED]Icons not found
Re: [SOLVED]Icons not found
You could install TabBar module and after select corresponding workbenches under Autoload tab:BuckyBall wrote:Is there currently a better solution to this issue than either editing the Python script, creating a Macro (neither of which I know how to do yet), or manually opening the relevant WorkBenches prior to opening the WB with my customized ToolBar?
https://forum.freecadweb.org/viewtopic. ... 20#p113369
P.S. Note that sooner or later i will move Autoload functionality to a standalone module.
- DeepSOIC
The problem is that the py files where the commands are defined do not load the necessary resource files. This can be fixed by locating the files, and adding "import somethingsonething_rc.py" lines. I have myself added an openscad refine button to Part workbench, and it shows up as a missing icon.
