Strange character on input numbers [SOLVED]
Hello folks!
I have a problem with my FreeCAD enviroment. On the menus, when an input number is requried, some strange characters appears instead. If the proper number are typed it works fine, but is annoying to have this characters and loose the reference of what value was before... I was wondering if any of you can help me to solve this thing. I've attached a capture of one menu so you can see the problem.
Thank you in advance!
FreeCAD information:
OS: Windows 7
Version: 0.15.4671 (Git)
Branch: releases/FreeCAD-0-15
Hash: 244b3aef360841646cbfe80a1b225c8b39c8380c
Python version: 2.7.8
Qt version: 4.8.6
OCC version: 6.8.0.oce-0.17
OS: Windows 7
Qt version: 4.8.6
- Menu.png (27.89 KiB) Viewed 1719 times
- DeepSOIC
Re: Strange character on input numbers
Hi!
I'd be curious to know, what are language settings on your Windows? Maybe it's trying to print something else than Arabic numbers...
Hi DeepSOIC!
The system language is Spanish. I've checked the FreeCAD settings and tried English and Spanish but the problem persists.
Any clue of what could be happening?
You could try updating to a 0.16 snapshot as 0.15 is very nearly obsolete, if the problem does not persist then it will no longer matter soon anyway, but if the problem does still persist then its probably relevant.oldsphere wrote:Hi DeepSOIC!
Good idea but the problem still persists...
FreeCAD info:
OS: Windows 7
Version: 0.16.6348 (Git)
Hash: 5fbdd4ac6624e32ba3a3e5523a31d56fe3ba7ae6
Qt version: 4.8.6
FreeCAD info:
OS: Windows 7
Qt version: 4.8.6
OK, one thing you could try is renaming the config files, so that when FreeCAD starts it generates new ones all with default values....that would determine if it is something in the settings somewhere causing the issues.oldsphere wrote:Good idea but the problem still persists...
- wandererfan
Edit > Preferences > General > Editor
Is the value in "Family" a reasonable font name? (Arial, TimesNewRoman, etc)
wf
wf
It was on Calibri. I've changed to Arial for trying and nothing changed, same problem.wandererfan wrote:Edit > Preferences > General > Editor
wf
The 0.16 version that I found was already compiled and I've executed it straightly without any installation process. I looked around on the folder for configuration files but threre wasn't any luck. Lots of DLLs but nothing I could identify as a config file. Where should I look for them?jmaustpc wrote:OK, one thing you could try is renaming the config files, so that when FreeCAD starts it generates new ones all with default values....that would determine if it is something in the settings somewhere causing the issues.
All versions on your system share the same config files. Type %APPDATA%/FreeCAD into the address bar and you will see them. system.cfg and user.cfg
"fight the good fight"
Ok, now I've found them. Thank you! However, the problem is still there...
