Abraham wrote:yeah the catalogues are littlebit confusing
To be honest i usually find catalogues a valuable resource of informations as big manufactures usually produce standard components. And if i compare looking for something in catalogue where the data is exact and images are added compared to "local guidelines" where the text is usually vague and refers to standards that usually can't be obtained without paying for a fee...
forgive my i just started FreeCad on the 5th, still learning how it does things and how to get it to do what i want
NormandC wrote:
triplus wrote:As for module 0.75 it is not standard value but maybe you don't have standard gear in the first place
According to this, 0.75 module is indeed a standard.
As Abraham wrote for 18 teeth it gives an outer diameter of 15mm.
I checked for reference in another "hard copy" book intended for providing information for this sort of things in our country. Well it is a bit old and the standard module list only provides a portion of values (bigger module). After i looked what mentioned manufacturer has to say about it:
And on T-21 page there is a table and Series 1 gears are refereed to as preferred choice. The values are consistent with my local standards therefore i would say if you want to follow standards better to stick with 0.6 or 0.8 in this range.
There was a problem using the WB with FreeCAD 0.15.xxxx, it only worked with 0.16.xxxx
A recent commit https://github.com/looooo/FCGear/commit ... 78e7cd1467 should have fixed it. Can you try the latest version of the macro and report if it is fixed for you.
it worked for me
I just copy/paste the FCGear directory into my FreeCAD Mod directory
OS: Ubuntu 14.04.3 LTS
Version: 0.16.6397 (Git)
Build type: Debug
Hash: 6763d3a6e48b6f74d48bca593baa8773897c7220
Python version: 2.7.6
Qt version: 4.8.6
OCC version: 6.9.1.oce-0.18-dev
